AAA Source Interface
Patrick McHenry
Level 7
Level 7
is there a way to make aaa authentication requests source from a specific interface on a device? On remote DMVPN devices there are two tunnel interfaces and one VLAN 10 interface. The DMVPN device seems to send requests from one tunnel address or the other so, to get around this I have entered both tunnel IP scopes in the ACS server. This solves the problem but, if I could send aaa requests out the VLAN 10 interface - then, I would only have to enter one scope in the ACS server.
Thanks, Pat.
John Blakley
Patrick,
You should be able to use "ip tacacs source vlan x".
Hth,
John
HTH, John *** Please rate all useful posts ***
6 Replies 6
cadet alain
yes you have the tacacs-server source-interface and radius-server source-interface commands.
Regards.
Alain
Alain,
it appears my router doesn't have that command.
Router(config)#tacacs-server ?
  administration    Start tacacs+ deamon handling administrative messages
  attribute         Customize selected tacacs attributes
  cache             AAA auth cache default server group
  directed-request  Allow user to specify tacacs server to use with
`@server'
  dns-alias-lookup  Enable IP Domain Name System Alias lookup for TACACS
                    servers
  domain-stripping  Strip the domain from the username
  host              Specify a TACACS server
  key               Set TACACS+ encryption key.
  packet            Modify TACACS+ packet options
  timeout           Time to wait for a TACACS server to reply
Hi Patrick,
I don't know how my mind created this unknown command and really sorry having given you an incorrect reply that you rated.Of course the correct command was given by John.
Regards.
Alain
No sweat - I'm pretty liberal with my rates.
I'm just happy when someone gives me a response - I'll take any help I can get.
Thanks,  Alain. Can't rate that one though : )
John Blakley
Patrick,
Hth,
John
mahmoodmkl
Level 11
Level 11
use ip tacacs source interface
