BGP nei opensent state
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-04-2008 09:42 AM - edited 03-05-2019 10:45 PM
hi everyone,
i had this on my router
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
10.254.5.182 4 21302 41005 13798 0 0 0 02:51:07 OpenSenti was unable to ping the nei router10.254.5.182.Is it problem with circuit or bgp???
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-04-2008 09:56 AM
Mahesh,
You need IP connectivity to the neighbor address before you can establish a neighbor relationship to it. So unless you have an ACL that specifically denies ICMP, not being able to ping means that you will not see that neighbor relationship forming. You should definitely check the circuit first.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-04-2008 10:50 AM
thanks for reply
so in this case both circuit and BGP ne is down right?
thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-04-2008 03:11 PM
Mahesh,
If you are using the directly connected interface IP address for the ping and it is not successful, I would suggect getting together with the service provider or whoever is responsible for that link to troubleshoot the basic IP connectivity. Unitil you determine the basic IP connectivity issue, you don't even need to care about the BGP session.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-05-2008 08:53 AM
thanks for reply
it was issue at telco end.
fixed now
