Bridge-group
azi123
Hi every one,
 I have cisco 2960g (2960g-24TC-) which runs IOS 12.2(55)SE-BASE-CRYPTO. I have a problem to define multiple Bridging groups. The CLI shows that the " host_name (config)#interface BVI" is a available command, but no way of defining new BVI by interface number. The screenshot shows this problem.
Could you please help me with this problem?
as far as I recall, bridging (IRB) is not supported on the 2960.
Julio E. Moisa
As Georg mentioned it is not support on this model.
Basically Bridge groups can be created on Layer 3 devices like routers or firewall and probably on some robust multilayer switches.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello
Was just wondering thiis switch although it’s really only a L2 switch it  does have limited routing capability but you need to be using the correct SDM template that that capability  -
show sdm prefer
However if the other guys have already checked that IRB isn’t applicable then changing the switch to the above template would make no difference.
Kind Regards
Paul
They can also be created on Access Points which are layer 2 devices. :)
