Showing results forĀ
Search instead forĀ
Did you mean:Ā
c870 ip nat port range
cgarlick1972
I need to nat ports 7000-7500 I have done it in the past port by port using:
ip nat inside source static tcp X.X.X.X 1234 interface FastEthernet4 1234
Do I need to do this via ip nat or access list?
balaji.bandi
Is the all the ports forwarding to same IP or different IP ?
Different IP then you need to use static Mapping each for that to work.
BB
