C9300-NM-8X card - only for sfp+?
vstepanov
please, could someone help me to find information about if C9300-NM-8X card supports sfp or sfp+ only. So is it possible to use for 1gigabitethernet port.  The only indirect prove that it's possible I found in the document
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_011.pdf
on p.5 All ports in the C9300-NM-8X module defaultt to 10G and should be configured asTenGigabitEthernet1/1/1 through TenGigabitEthernet1/1/8, even when you are operating the m as1G using SFP.
Thanks in advance!
Mark Malone
Yes it does
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_01001.html
Table 2  Network Modules
Network Module1 Description
C9300-NM-4G
This module has four 1G SFP module slots. Any combination of standard SFP modules are supported. SFP+ modules are not supported.
If you insert an SFP+ module in the 1G network module, the SFP+ module does not operate, and the switch logs an error message.
C9300-NM-8X
This module has eight 10G slots with an SFP+ port in each slot. Each port supports a 1G or 10G connection.
C9300-NM-2Q
This module has two 40G slots with a QSFP+ connector in each slot.
C9300-NM-BLANK
Insert this blank module when the switch has no uplink ports (this is required for sufficient air flow).
8 Replies 8
Mark Malone
Yes it does
C9300-NM-4G
C9300-NM-8X
C9300-NM-2Q
C9300-NM-BLANK
Thanks, Mark
Thanks this was very useful !
Hello experts,
I have an inquiry, I have a 9300 but with module C9300-NM-8X, my wonder is why is seen in the show run the fortiGig and the TwentyFiveGig interfaces?
Depending on which NM you install it is just prepared. Like a template.
LMCisco
Base on the document here:
Installing Network Modules C9300 series
They should be configured as 10G, but you can use a SFP (instead of SFP+) and operate them as 1G.
"C9300-NM-8XModuleAll ports in the C9300-NM-8Xmoduledefaultto 10 G and shouldbe configuredas TenGigabitEthernet1/1/1throughTenGigabitEthernet1/1/8,even when you are operatingthem as 1 G using SFP."
chandankumar
when i put NM card with cisco 9300 catalyst switch then NM  interface is not show in my switch why
chandankumar
if any one can help me then please sand me reply
