04-14-2022 02:19 AM
Question for the Cisco Community hive mind:
I'm down the rabbit hole on a topology re-design (where a 3rd party firewall will separate groups switches), and I want to maintain a single VTP and PTP hierarchy.
Yes, I know, fact that I'm posting this question here is the biggest indicator that I should find my way out and burn my current draft!
04-14-2022 06:26 AM
Manangement interface mainly for Managing the device like OOB managment, its belong to VRF or just manangement
i do not believe you can use any of the purpose you thinking to do i guess (honestly never tested, never got that requirement to use mgmt - since we have many other ports to use for the same purpose uplink ports)
04-14-2022 07:39 AM
Think of a management interface as a "host" interface, where you connect your switch to another switch to be accessible out-of-band for management. So, no VTP. PTP, etc.
05-10-2022 01:34 AM
I'll try it and let you know which protocols pass (PTP, VTP, etc.)
05-10-2022 07:05 AM - edited 05-10-2022 07:07 AM
Ethernet management port is not layer 2 switchport so VTP will not work on it. It is also not listed in supported features in configuration guide. PTP might work since it would be IP packet.
Ashish
