Catalyst 1000 issues with gui loading
netstudent88
Frequent Visitor
Frequent Visitor
I lost my password and used a method described in here to recover my password How to factory reset a C1000 Switch from boot mode.
I interrupted the boot sequence and then executed these commands
switch: rename flash:config.text flash:config.text.old
then i was able to get back into switch and get back to default settings.
However, now the gui is loading like this. Why is that? How do i correct this?
amikat
Please find beneath an excerpt from the "Release Notes for Cisco Catalyst 1000 Series Switches, Cisco IOS Release 15.2(7)Ex":
If the Web UI does not load or work properly after the software upgrade, perform the following steps:
  • Specify the authentication method for HTTP server users as local.
Device(config)# ip http authentication local
  • Configure the username and password with privilege 15.
Device(config)# username user privilege 15 password password
  • Clear the browser cache and relaunch the Web UI.
  • Login by entering the privilege 15 username and password.
Good Luck!
Best regards,
Antonin
5 Replies 5
Cisco Catalyst 1000 Factory Reset. Subscribe if you are a technology lover because more videos like this are coming soon for you all great of technology. Thanks for watching and keep learning.
Mark Elsen
  -   FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo35537
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
this doesn't really provide a fix. What can I do to get the GUI back to how it was?
   - The issue is to be considered cosmetic and can be safely ignored ,
 M.
amikat
Good Luck!
Best regards,
Antonin
