Catalyst 3850 switch not factory resetting after pressing mode button
mandb2412
My company was gifted a few Catalyst 2850 switches.  All, I want to do is perform a factory reset of these switches.  Before, anyone I asks I don't have any of the login passwords or any other login information for these switches.  I don't even know what ISO is installed.  I have pressed mode button and none of the expected behavior has occurred when doing a factory reset this way.  Is there any other way to do this?????  I noticed a reset button on the back of the switch will this button do anything?  I'm only going to spend a day on this and if the reset doesn't work, I going to chuck them into garbage.
11 Replies 11
power down/power up the switch with the reset button pressed for >12 seconds...does the status LED change ?
sorry wrong response
balaji.bandi
Is this 3850 switch or 2850 router ? Maybe password reset disabled? can you post a complete boot log connecting console?
BB
I'm unable to do anything to this switch.  I pressed the reset multiple times and nothing happens.  I'm in the console window and it still has the old domain information. I just want to wipe it clean and start fresh out of a box.  Is there a way to wipe out a switch to factory defaults without knowing anything about the switch?
Leo Laohoo
  1. Power down the switch.
  2. Hold the Mode button.
  3. Keep holding the button and apply power.
  4. Keep holding down the Mode button for another 45 seconds and then release
  5. See if the console goes to ROMMON or not.
  6. If in console, enter this command:  SWITCH_IGNORE_STARTUP_CFG=1
  7. Reload the switch (use the power cable).
  8. Go to enable mode and enter the following command:  factory-reset all
WARNING:  This command will delete everything in the flash, including the IOS.
Thank you! This is exactly what I needed
mandb2412
The switch appears to be booting up going though the motions of interfaces are down and the process stops at switch 3: power supply B is not responding which makes sense since I only have one power plugged in.  I attached a few images of when the switch finally boots up.  I don't think, I'm explaining myself properly,  my company took possession of a building and within the IT rooms we found (10) of the Catalyst 3850 switches and we want to use them.  Can we wipe them without knowing any of the passwords?
You can't wipe them out without the password. I recommend first doing a password recovery on each switch and then you can "write erase" the config and start fresh.
https://www.youtube.com/watch?v=O7RI3xyveCo
Thanks, for the help.  I have watch the video a few times and I'm not able to get to the following screen "The system has been interrupted prior....."  When the switch finishes booting up, I get to base Ethernet mac address screen but what's included is the motherboard serial number, and model information.  The IOS installed on the switch is: IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9- M), Version 16.3.6, RELEASE SOFTWARE (fc3).  Am I missing a step?
what are the options at the:
switch:
prompt ?
switch: ?
Make sure you have a usb flash drive with the IOS for your switch use the following command when prompted switch:
boot usbflash0:
