08-01-2019 06:18 AM
Dears.
I have a catalyst 9407 switch,with SUP-1XL which i tried to insert a GLC-LH-SMD tranciever into it.
The tranciever was detected as "inserted", but when i connect the fiber cable to it, it just did not came up.
Any idea
08-01-2019 06:33 AM
08-01-2019 06:35 AM - edited 08-01-2019 06:35 AM
suggest to check the light on the fibre, also on the interface, reverse the patch leads like below
SFP-----Light--------------No light ---patch
SFP-----No Light-------------Light ---patch
08-01-2019 06:39 AM
08-01-2019 07:22 AM
08-01-2019 08:12 AM
Ok here comes tricky one..(if the same one working on other switch)
So we need more information, ( i have come across this issue with 3750 with one of IOS was same issue)
(9300 to 3750 - move to differnt IOS of 3750 all worked).
what is end to end Device connecting.
post the interface config also show version of both.
08-02-2019 04:58 AM
