Switching
Labels
Hello Cisco community,  I have a Cisco 9200L.  For some reason, we have had no luck migrating from password 7 to password 6.  Each time I attempt config, it gives me an error.  I even tried a new switch for additional testing, but still gives same re...
Am getting a little obssed over networking over the last few days and decided to go for ccna and i started learning and reached ACL ,specifically extended ACLs ,but when i was trying a hands on in CPT i got stuck . since i dont have a proper mentor i...
Mark Alpha by Community Member
  • 190 Views
  • 5 replies
I recently replaced the core switch at one of my sites that consisted of two separate C9300-48Ts and three other off brand switches and installed a new stack with a C9300X-48HX, C9300-24S and a C9300-48T (running 17.12.5). This is a layer 2 network c...
dbronco by Level 1
  • 123 Views
  • 4 replies
This morning, I found that the C9115 AP led light connected to the C9300L-24P-4X switch blinks red-green-blue cyclically, and I checked the POE switch and found that the poe status of the port connected to the AP is down, but I can see that the inter...
id404 by Spotlight
  • 115 Views
  • 2 replies
I recently got an IEM-16P expansion module for an IE-3300-8P2S and cannot get it to pass POE. I've tried the expansion module on two separate 3300 base switches with the same result.  With a 48VDC 480W power supply I can power an IE-3300-8P2S with an...
dbronco by Level 1
  • 183 Views
  • 6 replies
Recently need to upgrade C9407 Current version: 16.12.03aTarget version: 17.9.6a Supervisor 1 XL Module with 25G FW: 16.12.2rCPLD: 19032905 Two 9407 SVL units---Can't find the upgrade path in official documentation?Can we upgrade directly from 16.12...
jeff-sie by Level 1
  • 490 Views
  • 17 replies
Hi guys .The SOC administrator in my department told me that, for the purpose of securing the network, I should disable the password recovery service so that no one can access the switch configurations just by having a console cable. But I’m not sure...
chpmotry by Level 1
  • 263 Views
  • 10 replies
I'm a new user of Cisco products in a public transportation agency and I'm working with both the Cisco 819 and 829 routers. These devices are installed on a large fleet of vehicles.We have written procedures for setting up both models, but the engine...
Cpt Mocha by Level 1
  • 285 Views
  • 7 replies
