Cisco 3064 switch upgrade from 6.0.x to 7.0.x issue
satish.txt1
Level 3
Level 3
I am trying to upgrade from 6.0.2.U6.5c to nxos.7.0.3.I4.7, before upgrade i want to make sure it pass all checks but i got this error. This switch isn't in production yet but want to make sure it goes well and smooth. Am i doing something wrong?
Software
  BIOS:      version 2.6.0
  loader:    version N/A
  kickstart: version 6.0(2)U6(5c)
  system:    version 6.0(2)U6(5c)
  Power Sequencer Firmware:
             Module 1: version v1.0
  SFP uC:    version 2.12
  BIOS compile time:       08/06/2014
  kickstart image file is: bootflash:///n3000-uk9-kickstart.6.0.2.U6.5c.bin
  kickstart compile time:  4/6/2016 22:00:00 [04/07/2016 05:46:42]
  system image file is:    bootflash:///n3000-uk9.6.0.2.U6.5c.bin
  system compile time:     4/6/2016 22:00:00 [04/07/2016 06:14:31]
Error:
Pre-upgrade check failed. Return code 0x40930012 (SRG extraction failed).
 see full output.
switch# show install all impact system bootflash:nxos.7.0.3.I4.7.bin
Installer is forced disruptive
Verifying image bootflash:/n3000-uk9-kickstart.6.0.2.U6.5c.bin for boot variable "kickstart".
[########################################] 100% -- SUCCESS
Verifying image bootflash:/nxos.7.0.3.I4.7.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/nxos.7.0.3.I4.7.bin.
[#                                       ]   0% -- FAIL. Return code 0x404F0003 (SRG file not present/cannot be opened).
Notes: I have also verify no TCP connection is opened base on this bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut84783/?referring_site=bugquickviewredir
Also i have "reload" it many time to clean up /var/tmp. I am not seeing any space issue too.
switch# show system internal flash
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/                            409600     77460      332140     19   /dev/root
/proc                             0         0           0      0   proc
/post                          2048         4        2044      1   none
/var                         409600     77460      332140     19   none
/sys                              0         0           0      0   none
/debugfs                          0         0           0      0   nodev
/isan                       1536000    784452      751548     52   none
/nxos/tmp                     40960        48       40912      1   none
/var/tmp                     409600      9056      400544      3   none
/var/sysmgr                  921600       128      921472      1   none
/var/sysmgr/ftp              307200       100      307100      1   none
/var/sysmgr/ftp/cores        102400         0      102400      0   none
/dev/shm                     643072    182692      460380     29   none
/volatile                    102400         0      102400      0   none
/debug                        20480         0       20480      0   none
/dev/mqueue                       0         0           0      0   none
/mnt/cfg/0                   114171      4149      104127      4   /dev/sda5
/mnt/cfg/1                   113193      4149      103200      4   /dev/sda6
/var/sysmgr/startup-cfg      409600        20      409580      1   none
/dev/pts                          0         0           0      0   devpts
/mnt/pss                     114203      6137      102170      6   /dev/sda4
/mnt/plog                     49024      1564       47460      4   /dev/mtdblock
In last option i have upgrade BIOS from 2.6 to 4.0.0, still no luck
Software
  BIOS:      version 4.0.0
  loader:    version N/A
I have confirmed md5sum too to make sure file isn't modified while copying.  Any suggestion?
5 Replies 5
Reza Sharifi
Do both the kick start image and system image exist on the flash?
What is the output of "dir"?
In 7.x version they don't have kickstart separate file so i have tried following but still not working
switch# show install all impact kickstart bootflash:nxos.7.0.3.I4.4.bin system bootflash:nxos.7.0.3.I4.4.bin
Notes: This time i am trying following file instead of nxos.7.0.3.I4.7.bin (but getting same error)
nxos.7.0.3.I4.4.bin
switch# dir
       4096    Oct 30 21:33:59 2017  .patch/
         84    Jul 12 14:11:37 2017  20170712_141119_poap_3679_init.log
        168    Oct 30 21:19:12 2017  20171030_211744_poap_3681_init.log
       1960    Nov 14 16:43:55 2017  20171114_164207_poap_3924_init.log
       1225    Nov 14 18:39:58 2017  20171114_183847_poap_3926_init.log
        173    Nov 14 17:55:24 2017  dhclient_log
   37857280    Oct 30 21:25:27 2017  n3000-uk9-kickstart.6.0.2.U6.5c.bin
  206969903    Oct 30 21:25:59 2017  n3000-uk9.6.0.2.U6.5c.bin
  699334656    Nov 14 18:58:09 2017  nxos.7.0.3.I4.4.bin
       1024    Oct 30 21:33:42 2017  sprom_cstruct_2_0_0
       1024    Oct 30 21:34:16 2017  sprom_cstruct_3_0_0
       4096    Jan 29 01:54:24 2010  vdc_2/
       4096    Jan 29 01:54:24 2010  vdc_3/
       4096    Jan 29 01:54:24 2010  vdc_4/
       4096    Jan 29 01:54:24 2010  virt_strg_pool_bf/
       4096    Oct 30 21:34:00 2017  virtual-instance/
Usage for bootflash://
1060663296 bytes used
548614144 bytes free
1609277440 bytes total
I think I just figured this out. In 7.x don't use the "install all system bootflash:..." use "install all nxos bootflash:..." This seems to kick off a whole different install process.
Issue
switch# show install all impact system bootflash:nxos.7.0.3.I4.1.bin (Note - there is no option for “show install all impact nxos”)
Verifying image bootflash:/n3000-uk9-kickstart.6.0.2.U6.6.bin for boot variable "kickstart".
[#                                       ]   0% -- FAIL.
Searches on Cisco support forum site suggests this error is related to bootflash space/ established SFTP connections/ var/tmp directory. And the workaround (reload/clearing bootflash) from Cisco support forum didn’t work.
In this case, I execute install instead of verification as suggested on one of the forum and it works.
switch# install all nxos bootflash:nxos.7.0.3.I7.1.bin
Verifying image bootflash:/nxos.7.0.3.I7.1.bin for boot variable "nxos".
Extracting "nxos" version from image bootflash:/nxos.7.0.3.I7.1.bin.
Extracting "bios" version from image bootflash:/nxos.7.0.3.I7.1.bin.
Performing runtime checks.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module    bootable    Impact     Install-type           Reason
     1          yes           disruptive    reset                   Unsupported in new image, module needs to be powered off
Images will be upgraded according to following table:
Module             Image            Running-Version                     New-Version                           Upg-Required
     1         kickstart                  6.0(2)U6(6)                                             7.0(3)I7(1)                               yes
     1         bios                         v1.2.0(08/25/2011)                 v4.4.0(07/12/2017)                 yes
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)?  [n] y
Thanks  yes it is working with me also to upgrade to nxos.7.0.3.I2.2b.bin
NX3000# install all nxos bootflash:
bootflash:/// bootflash://sup-1/ bootflash://sup-local/
bootflash://module-1/ bootflash://sup-active/
NX3000# install all nxos bootflash:///
bootflash:///.patch
bootflash:///20010101_131936_poap_4119_init.log
bootflash:///NX3000-startup-config
bootflash:///n3000-uk9-kickstart.6.0.2.U6.10.bin
bootflash:///n3000-uk9.6.0.2.U6.10.bin
bootflash:///nxos.7.0.3.I2.2b.bin
bootflash:///nxos.7.0.3.I7.9.bin
bootflash:///platform-sdk.cmd
bootflash:///sprom_cstruct_2_0_0
bootflash:///sprom_cstruct_3_0_0
bootflash:///vdc_2
bootflash:///vdc_3
bootflash:///vdc_4
bootflash:///virtual-instance
NX3000# install all nxos bootflash:///nxos.7.0.3.I2.2b.bin
Verifying image bootflash:/nxos.7.0.3.I2.2b.bin for boot variable "nxos".
Extracting "nxos" version from image bootflash:/nxos.7.0.3.I2.2b.bin.
Extracting "bios" version from image bootflash:/nxos.7.0.3.I2.2b.bin.
1 kickstart 6.0(2)U6(10) 7.0(3)I2(2b) yes
1 bios v1.7.0(06/23/2014) v3.5.0(09/14/2015) yes
Time Stamp: Thu Aug 5 01:22:17 2021
Install is in progress, please wait.
Setting boot variables.
Performing configuration copy.
Module 1: Refreshing compact flash and upgrading bios/loader/bootrom/power-seq.
Warning: please do not remove or power off the module at this time.
Note: Power-seq upgrade needs a power-cycle to take into effect.
On success of power-seq upgrade, SWITCH OFF THE POWER to the system and then, power it up.
Time Stamp: Thu Aug 5 01:26:07 2021
Finishing the upgrade, switch will reboot in 10 seconds.
NX3000# [ 2078.692035] writing reset reason 49,
