Cisco 4500 - SUP-6E - HIGH CPU Utilization
Stepan Vesely
Hello cisco specialists,
I supervise on LAN network and it seems that cpu has high utilization - even at night, when nobody is at work!
Somebody with same problem or anybody who good give me some tips?
Sa Miss :
The behavior changed in Cisco IOS Releases 12.2(50)SG4, 12.2(53)SG, or later; packets are processed
in hardware and no extra copy is sent to the CPU. (CSCsu81046)
* I got there 12.2(54)SG1
Adj SameIf Fail  :
Packets that is routed out of the same interface.
* Historically between this GW (4500) and ASA FW is VRF configuration...maybe?
Here is some show reports:
sh processes cpu sort
CPU utilization for five seconds: 80%/2%; one minute: 80%; five minutes: 80%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
57   319024866     1148670293     277 70.07% 70.23% 70.36%   0 Cat4k Mgmt LoPri
56    36493723         97272812       375  6.55%  6.06%  6.21%   0 Cat4k Mgmt HiPri
108     3678708          2290993       1605  2.07%  0.75%  0.40%   0 SpanTree Flush
121     5412953          2487404       2176  1.43%  0.99%  0.96%   0 Spanning Tree
sh platform health
                                    %CPU %CPU   RunTimeMax   Priority      Average %CPU  Total
                                    Target Actual    Target Actual   Fg   Bg      5Sec Min Hour  CPU
K5CpuMan Review          30.00  46.98     30     23        100  500        68  58   55  6002:30
K5ForerunnerPacketMa   1.50    26.16      4      0          100  500        35  29   24  2641:47
sh platform cpu packet statistics
RkiosSysPacketMan:
Packet allocation failures: 0
Packet Buffer(Software Common) allocation failures: 0
Packet Buffer(Software ESMP) allocation failures: 0
Packet Buffer(Software EOBC) allocation failures: 0
Packet Buffer(Software SupToSup) allocation failures: 0
IOS Packet Buffer Wrapper allocation failures: 0
Packets Dropped In Processing Overall
Total                5 sec avg 1 min avg 5 min avg 1 hour avg
            34555740         4        15        25         15
Packets Dropped In Processing by CPU event
Event             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Sa Miss                       34091682         3        14        24         15
L2 Router                          524         0         0         0          0
Input Acl Fwd                      467         0         0         0          0
Input ACl Copy                  463067         0         0         0          0
Packets Dropped In Processing by Priority
Priority          Total                5 sec avg 1 min avg 5 min avg 1 hour avg
Normal                          464057         0         0         0          0
Medium                        34091682         3        14        24         15
High                                 1         0         0         0          0
Packets Dropped In Processing by Reason
Reason             Total                5 sec avg 1 min avg 5 min avg 1 hour avg
SrcAddrTableFilt                     15         0         0         0          0
STPDrop                              46         0         0         0          0
AclActionDrop                       119         0         0         0          0
NoDstPorts                          345         0         0         0          0
Tx Mode Drop                   34554691         4        15        25         15
Extra packet due to RxProc hwAssisted Bridging                  524         0         0         0          0
Total packet queues 64
Packets Received by Packet Queue
Queue                                 Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                               45142376        83        68        64         55
Input ACL fwd(snooping)     10066057        22        14        13          3
L2 bridge to CPU, 0           17114371        59        33        28         20
Host Learning                    34073570         4        15        24         15
L2 Control                           6913331        11         7         7          0
Input ACL log, unreach          463060         0         0         0          0
Ttl Expired                               7282         0         0         0          0
Adj SameIf Fail            5699045684      2491      2328      2139       6378
L2 router to CPU, 7               507862         0         0         0          0
L3 Glean, 7                         1044562         2         0         0          0
L3 Receive, 7                       3581175        13         7         7          1
Packets Dropped by Packet Queue
L2 bridge to CPU, 0                230         0         0         0          0
Host Learning                   256610         0         0         0          0
Adj SameIf Fail               21900926         1         0         1          5
Packets Transmitted from CPU per Output Interface
Interface              Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Gi2/1                            49740         0         0         0          0
Gi2/2                            42479         0         0         0          0
Gi2/5                            94568         0         0         0          0
Gi2/6                            93600         0         0         0          0
Gi2/9                            52403         0         0         0          0
Gi2/11                           93883         0         0         0          0
Gi2/13                           94954         0         0         0          0
Gi2/14                             477         0         0         0          0
Gi2/15                           92711         0         0         0          0
Gi2/16                             477         0         0         0          0
Gi2/17                           93523         0         0         0          0
Gi2/18                           93511         0         0         0          0
Gi4/1                            92340         0         0         0          0
Gi4/2                             1003         0         0         0          0
Gi4/14                            8500         0         0         0          0
Gi4/15                            8503         0         0         0          0
Gi4/16                           93308         0         0         0          0
Gi4/17                            8501         0         0         0          0
Gi4/19                            1987         0         0         0          0
Gi4/21                            8500         0         0         0          0
Gi4/22                            8500         0         0         0          0
Gi4/23                           92339         0         0         0          0
Gi4/24                            3173         0         0         0          0
Gi4/25                            3435         0         0         0          0
Gi4/26                            3182         0         0         0          0
Gi4/27                            9644         0         0         0          0
Gi4/28                            3175         0         0         0          0
Gi4/29                            3352         0         0         0          0
Gi4/30                            3351         0         0         0          0
Gi4/31                            8500         0         0         0          0
Gi4/33                           92340         0         0         0          0
Gi4/35                            3175         0         0         0          0
Gi4/36                            3176         0         0         0          0
Gi4/37                           93605         0         0         0          0
Gi4/38                            3175         0         0         0          0
Gi4/39                            3175         0         0         0          0
Gi4/40                            3175         0         0         0          0
Gi4/42                            3175         0         0         0          0
Gi4/46                           92340         0         0         0          0
Gi6/1                            52034         0         0         0          0
Gi6/2                             4777         0         0         0          0
Gi6/3                             8507         0         0         0          0
Gi6/4                             3366         0         0         0          0
Gi6/5                             8674         0         0         0          0
Gi6/6                             8662         0         0         0          0
Gi6/7                             4725         0         0         0          0
Gi6/8                               41         0         0         0          0
Gi6/9                            93308         0         0         0          0
Gi6/11                           15952         0         0         0          0
Gi6/12                            9546         0         0         0          0
Gi6/13                            3443         0         0         0          0
Gi6/14                              41         0         0         0          0
Gi6/15                              41         0         0         0          0
Gi6/16                            8506         0         0         0          0
Gi6/20                            3863         0         0         0          0
Gi6/21                            8761         0         0         0          0
Gi6/22                              41         0         0         0          0
Gi6/24                            8722         0         0         0          0
Gi6/28                            3339         0         0         0          0
Gi6/29                            8671         0         0         0          0
Gi6/30                            8672         0         0         0          0
Gi6/31                            8672         0         0         0          0
Gi6/32                            3339         0         0         0          0
Gi6/33                           92340         0         0         0          0
Gi6/34                           56951         0         0         0          0
Gi6/35                            1327         0         0         0          0
Gi6/36                            2556         0         0         0          0
Gi6/37                           92339         0         0         0          0
Gi6/39                            8668         0         0         0          0
Gi6/40                            3339         0         0         0          0
Gi6/45                            4778         0         0         0          0
Gi6/46                           93072         0         0         0          0
Gi6/47                            1405         0         0         0          0
Gi6/48                            1476         0         0         0          0
Te1/1                            66054         0         0         0          0
Te1/2                            52727         0         0         0          0
Packets Received at CPU per Input Interface
Gi2/1                              985         0         0         0        985
Gi2/2                              701         0         0         0        701
Gi2/5                            91755         0         0         0      91755
Gi2/6                             9073         0         0         0       9073
Gi2/9                             4147         0         0         0       4147
Gi2/11                           23063         0         0         0      23063
Gi2/13                            3488         0         0         0       3488
Gi2/14                            3633         0         0         0       3633
Gi2/15                            1048         0         0         0       1048
Gi2/16                             123         0         0         0        123
Gi2/17                            3188         0         0         0       3188
Gi2/18                           12470         0         0         0      12470
Gi4/1                              164         0         0         0        164
Gi4/2                                2         0         0         0          2
Gi4/14                               8         0         0         0          8
Gi4/15                            2515         0         0         0       2515
Gi4/17                               4         0         0         0          4
Gi4/21                               4         0         0         0          4
Gi4/27                             126         0         0         0        126
Gi4/28                               6         0         0         0          6
Gi4/29                             133         0         0         0        133
Gi4/30                             132         0         0         0        132
Gi4/33                            2440         0         0         0       2440
Gi4/35                              36         0         0         0         36
Gi4/37                            1113         0         0         0       1113
Gi4/38                            2594         0         0         0       2594
Gi4/40                               6         0         0         0          6
Gi4/42                            2474         0         0         0       2474
Gi4/46                              47         0         0         0         47
Gi6/1                            28612         0         0         0      28612
Gi6/2                               47         0         0         0         47
Gi6/3                              149         0         0         0        149
Gi6/4                               20         0         0         0         20
Gi6/5                               24         0         0         0         24
Gi6/6                             2451         0         0         0       2451
Gi6/7                               27         0         0         0         27
Gi6/8                               95         0         0         0         95
Gi6/11                              28         0         0         0         28
Gi6/12                            3078         0         0         0       3078
Gi6/13                             202         0         0         0        202
Gi6/14                               2         0         0         0          2
Gi6/15                               8         0         0         0          8
Gi6/16                              63         0         0         0         63
Gi6/20                             707         0         0         0        707
Gi6/21                             170         0         0         0        170
Gi6/22                           16935         0         0         0      16935
Gi6/24                              97         0         0         0         97
Gi6/29                             350         0         0         0        350
Gi6/30                             263         0         0         0        263
Gi6/31                             506         0         0         0        506
Gi6/32                               1         0         0         0          1
Gi6/33                            2440         0         0         0       2440
Gi6/34                           24333         0         0         0      24333
Gi6/35                             534         0         0         0        534
Gi6/36                            1691         0         0         0       1691
Gi6/39                               9         0         0         0          9
Gi6/40                               1         0         0         0          1
Gi6/45                              32         0         0         0         32
Gi6/46                            9564         0         0         0       9564
Gi6/47                            1249         0         0         0       1249
Gi6/48                             150         0         0         0        150
Te1/1                           111091         0         0         0     111091
Te1/2                            23546         0         0         0      23546
Thank you for any advice.
Best Regards,
Steve
Stepan Vesely
Hello all readers,
If somebody would like, now I know the answer on this question.
I do some tests with traffic at night...how?
On GW I do a monitoring - all incoming packets to CPU I mirror to PC (wireshark installed)
Code:
conf t
monitor session 1 source cpu rx
monitor session 1 filter packet-type good rx
monitor session 1 destination interface gigabitEthernet X/Y
Find out, that some PC do a backup cross whole network to internet.
Have a nice day,
Steve
Hi Stepan,
Thanks for sharing your findings, glad to hear you have found the cause of this.
For your reference, please have a look at the following documentation which will help you to identify the reason for high CPU usage on 4500 switches.
High CPU Utilization on Cisco IOS Software-Based Catalyst 4500 Switches
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
Best regards,
Andras
So is there actually a solution here? Was it just a PC sending a backup to the internet.
I have a pair of newly-installed 4500X's exhibiting the EXACT same symptoms as in the OP (SA MIss, Adj SameIf Fail), and don't see a root cause as yet.
Hi Aumell,
Adj SameIf Fail packets indicate that packets are being routed out of the same interface, so basically these packets are sent to the CPU for ICMP redirect. If an IP unicast packet is to be routed via the port in which the packet originally was received on, it may be sent to the CPU so that software sends ICMP message to the source host. Disabling the reception and transmission of certain types of messages on an interface can minimize the amount of CPU load that is required to process unrequired packets.
Suggestion:
Use the no ip redirects configuration command on all the SVIs or L3 interface
Refer:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml#redirects
Useful commands to troubleshoot High CPU,
#show processes cpu - in order to identify the Cisco IOS processes that consume CPU cycles
#show platform health - Check CPU usage on platform depending processes. If K5CpuMan Review, execute the below command identity the type of traffic that hits the CPU
#show platform cpu packet statistics - Check traffic on the CPU queue
It would be good to see what kind of traffic is currently hitting the CPU using internal inband capture tool:
#debug platform packet all buffer
#ahow platform cpu packet buffered
Note: This debug does not affect CPU utilization much.
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
