Cisco ISSU 9500 upgrade issue
we did upgrade from 16.12.5b to 17.3.4 as ISSU.found too late ISSU matrix telling is not supported...
during upgrade chassis fell into a constant bootloop which we had to break using ROMMON.
now we try and stuck at:
switch5#install abort issu
may you advise on how to proceed ?
output log attached: log.txt
Best Regards
9 Replies 9
Mark Elsen
 - You may try this procedure : https://community.cisco.com/t5/switching/c9500-install-mode-issue/m-p/4509141#M514424
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
is this part of SVL ?
why it showing switch 5 ?
--- Starting preparation for software rollback ---
FAILED: No rollback file found for /bootflash/packages.conf
as per the information it not able to find the files, not sure what command you issued.
you need to break the SVL and put them in ROMMON do a traditional way upgrade and bring back to sVL.
BB
yes SVL - two switches, we are testing now , ps. switch 5 was example name
Leo Laohoo
Never, ever believe in the hype about ISSU &/or FSU/eFSU.
ISSU &/or FSU/eFSU usually work in "corner cases" like labs or demos.
IMPORTANT:  Upgrade to 17.3.5 instead.
Kindly refer to the PDF attached.  I have written an easy-to-understand procedure about how to upgrade the firmware of a stack of 9300 in Install Mode (the document even have pictures!).
IMPORTANT:  Read the Release Notes carefully.
thank you for sharing this document
l have few questions
should the ISSU have been accepted by 16. IOS if it was explicitly listed as improper upgrade ?
why we got stuck into in progress state ?
Best Regards
Usually, ISSU does not work when you upgrade from one major version to another (16.12.5b to 17.3.4), and that is most likely why you got stuck in progress.
Leo Laohoo
@Reza Sharifi
Have a look at CSCwc54402, CSCwh29442.  Interesting bugs, no?
I also seem to have the same problem with C9410 dual SUP with upgrade by DNA-C to 17.3.5 > 17.6.4
Redundant System Information :
Available system uptime = 2 hours, 21 minutes
Switchovers system experienced = 0
Standby failures = 4
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 5
Current Software state = ACTIVE
Uptime in current state = 2 hours, 21 minutes
Image Version = Cisco IOS Software [Bengaluru], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.6.4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Sun 14-Aug-22 08:58 by mcpre
BOOT = bootflash:packages.conf;
Peer Processor Information :
Standby Location = slot 6
Current Software state = in progress to standby cold-config
Uptime in current state = 19 minutes
CONFIG_FILE =
Same outputs as in bug report for "
show platform software iomd redundancy
show redundancy states
