Catalyst 4506-E switch stuck in rommon mode
ahmeeIT
I have an old cisco catalyst LE switch 4506-E, I have been using it for long period. Now when i power on, it displays the below error and goes to rommon mode.
* Rom Monitor NVRAM configuration is being initialized to *
* default values. This may be because it was never initialized.*
Writing to Primary Region failed
Writing to Backup Region failed
Rommon (G) Signature verification PASSED
flash0:/codesign/rm1.dat open failure
Rommon (P) Signature verification PASSED
flash0:/codesign/rm2.dat open failure
FPGA (P) Signature verification PASSED
flash0:/codesign/fpga.dat open failure
* Welcome to Rom Monitor for WS-C4500X-16 System. *
* Copyright (c) 2008-2012 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.0(1r)SG6
CPU Rev: 2.2, Board Rev: 4, Board Type: 108
CPLD Mobat Rev: 2.0x4377.0xb277
Chassis: WS-C4500X-16
MAC Address : f0-f7-55-c5-31-7f
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
So i try to see the image in the bootflash, if i execute the dir bootflash:, It displays as below and doesn't showed the content
rommon 1 >dir bootflash:
ExtX super block invalid signature
So i thought of booting the device with usb but no pendrive gets detected .it also fails as u can see below
rommon 2 >dir usb0:
No USB storage device detected!
Error[3]: Failed to open directory!
Can anyone suggest me what i can do further?
if it is the problem, i guess its time to open a TAC case in support
Good luck
KB
8 Replies 8
check below guide's step 5. even this is OS upgrade document, step 5 explains about setting boot value.
https://community.cisco.com/t5/networking-knowledge-base/how-to-upgrade-cisco-4500-sup7-e-sup7l-e-rommon-to-support-vss/ta-p/3145220
Good luck
KB
I think this is different. When enter “confreg=0x2101” to change the configuration register value, it display the following:
And if I enter
Output is the above.
Good luck
KB
balaji.bandi
Change the config register to 0x2102
rommon>set
rommon>unset boot
rommon>confreg 0x2102
rommon>reset
some reference to fix the issue.
https://community.cisco.com/t5/switching/issues-booting-4500x-switch/td-p/4567144
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_24829.html#wp196197
still not working time for RMA.
BB
ahmeeIT
Okay I'll try that way.
Thank you everyone
Leo Laohoo
Flash is dead.
Okay Sear;
Can I replace it or What should I do?
Do you have Flash? i suggest contacting TAC for RMA.
BB
