Command to view flexstack module in 2960S?
snyggsomfan
Is there any command that shows if a 2960S switch has the flexstack module installed or not? Thanks in advance!
/K
8 Replies 8
dhalevi
Level 3
Level 3
have you tried "show inventory" ?
Yes, I have tried both "show inventory" and "show inventory raw" on switches I know have and don't have the stacking module but I don't see any differences in the output.
/K
Bump
I am lookin for this as well.
show version
show inventory
show platform
show switch stack-ports
they all give the same output with or without a Flexstack module in the switch.
Try this:
"show version"
"show hardware"
Martin Cristian
Visitor
try
sh platform status
Merci - thank you - this works.
with stack module:
C2960S_TEST#sh platform status
Status: Normal
FlexStack Module Status: Normal
C2960S_TEST#
without stack module:
Status: Normal
C2960S_TEST#
You can also this command "show switch detail"
Switch/Stack Mac Address : 10bd.18d1.1980
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 10bd.18d1.1980     14     1       Ready
 2       Member 10bd.1876.4a00     1      1       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
