Copying files from flash:
mgalla3327
Hello everyone,
A quick questions...
I am trying to copy the files in the html dir on a 3524xl switch to a tftp server. I can copy the files individually using copy flash:html/filename tftp:
Is there a way to copy the entire html dir at once or is it only possible to do 1 file at a time?
Thanks for your help,
Matt
Edison Ortiz
I'm afraid the answer is, one at the time ...
Request to FIX that in future releases!!!
binhkdinh
I'm not sure if IOS on your 3524 supports "tar" or "archive tar" command. If yes, you might be able to tar the folder, then copy it to the tftp server.
glen.grant
I would just go out and download the .tar file for the image you want. All the html files are compressed inside that file .
