Switching
Labels
Hi guys .The SOC administrator in my department told me that, for the purpose of securing the network, I should disable the password recovery service so that no one can access the switch configurations just by having a console cable. But I’m not sure...
chpmotry by Level 1
  • 233 Views
  • 10 replies
I'm a new user of Cisco products in a public transportation agency and I'm working with both the Cisco 819 and 829 routers. These devices are installed on a large fleet of vehicles.We have written procedures for setting up both models, but the engine...
Cpt Mocha by Level 1
  • 263 Views
  • 7 replies
Hi Team,Users in my network are receiving bad IP addresses, and our DHCP scope is set up on a Microsoft Windows Server.Please assist me in resolving this issue and let me know if you need any information from my side.
Good Day All, I currently have a C9300-24P-E , brand new out the box. I see that we are going to need AVB support which is only supported under DNA-Advantage licensing............ I tried to run the "license boot level network-advantage" command to t...
Good morning, team. I have an issue with a WS-3650 version 16.12.13. It's configured correctly, but when I unplug it and plug it back in, it appears to be back to factory settings.I've already tried doing this to configure the registers.   config-reg...
I am trying to get a better understanding of why something is working.  SW1 is another vendors switch which connects there devices, SW2 is my switch which connects devices on my network.  SW1 and SW2 are connected via a trunk link that allows VLAN 30...
j-mol by Level 1
  • 187 Views
  • 7 replies
Greetings,I have aquired a second hand WS-C3650-8X24UQ-S. Appears to be working as is (connected to router and one pc), and no password. When looking up reset instructions, I see typically you flash_init, then delete config.text and vlan.dat (after h...
DH2025 by Level 1
  • 225 Views
  • 7 replies
The following ACL is set on the L3SW management interface.I think it is to control the outgoing communication from L3SW, but in the case of and below, I think it is possible to control the return communication only with access-group 100 in, so I thin...
CHISHIUNG by Level 1
  • 131 Views
  • 2 replies
