Does This Output Suggest a Problem
Patrick McHenry
Level 7
Level 7
I was wondering if this output form a core 3750 switch seems to be hoveriing on the high end? Thanks, Pat.
CoreSwitch#sh processes cpu hist
100
90                                 *
80                                 *
70               *                 *                     *
60        *      *     *           *   *** *      *   *  *  *
50  *     *      *     *           *  **** *     ** * ** *  *   ***
40 **   ***** *  * *  ***    **   *** **** ** ** ** **** ****   *** *  *
30 **********************************************************************
20 **********************************************************************
10 ######################################################################
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
                  * = maximum CPU%   # = average CPU%
GigabitEthernet1/0/26 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is f0f7.552c.201a (bia f0f7.552c.201a)
  Description: Etherchannel to Avaya Switch
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 45/255, rxload 5/255
  Description: Etherchannel to BR-5650-Stack
     reliability 255/255, txload 63/255, rxload 4/255
Seems to be going up - at what level should I be concerned?
Reza Sharifi
Pat,
The one you post it is for the last 72 hours.  What is it for the last 60 second and 60 minutes.
Even though you have some CPU spikes, the average is still at about 10
Regarding the interface, this could be normal, as the switches are in production and traffic traversing the interfaces.
Reza Sharifi
Pat,
