Ether Channel Limitation : 48
balachandhars
Hi all,
I have a stack of 4*3750 switches with 52 ports each (48 + 4). Is it possible to have port channels above 48th one in the stack in any way?
Thanks and Regards,
Balachandhar S
Anand G
Hi Balachandhar,
We can't go beyond 48 portchannels in the stack.
You can refer the below Cisco CCO doc for more details.
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094646.shtml#topic6a
Anand G (ag2)
** Please rate if you found this info. is useful **
   If you need more than 48 and i'll assume this is for servers of some type then you probably don't have the correct platform for large scale server deployments and need to look at something more robust like 4500's or 6500's.
ALIAOF_
Level 6
Level 6
4948's will do 64.
