Etherchannel between sg300 and Cisco4506 running CatOS
eneidercolina
What is the correct way to create a port channel between an SG300 and Cisco4506 running CatOS
Deepak Kumar
interface Port-channel2
description portchannel on sg300
switchport mode trunk
switchport trunk allowed vlan 2,4,6,8,10
interface gigabitethernet2
channel-group 2 mode auto
interface gigabitethernet3
interface Port-channel1
description portchannel on 4506
interface gigabitethernet 2/1
channel-group 1 mode auto
interface gigabitethernet 2/2
If you want to port channel as L3 interface then both member ports are must be L3.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak, the 4506 switch is running CatOS (cat4000-k8.8-4-11-GLX.bin) with1000BaseX Supervisor WS-X4013
i have an active port channel between the 4500 ports and 3560 the configuration is:
CatOS 4506
#port channel
set port channel 1/1-2 5 >>>>>>>>>>>>>port channel active
set port channel 2/25-28 8
set port channel 3/1-4 14
set port channel 3/45-48 25
set port channel 2/13-16 29
#module 1 : 2-port 1000BaseX Supervisor
set vlan 10   1/1-2
set port trap       1/1-2  enable
set trunk 1/1  on dot1q 1-1005,1025-4094
set trunk 1/2  on dot1q 1-1005,1025-4094
set port channel 1/1-2 mode desirable non-silent
#module 2 : 48-port 10/100/1000 Ethernet
set vlan 30   2/25,2/28,2/41
set vlan 94   2/37,2/48
set vlan 400  2/1-24,2/26-27,2/29-36,2/38-40,2/42,2/46-47
set vlan 962  2/43-45
set trunk 2/28 off dot1q 1-1005,1025-4094
set trunk 2/40 off dot1q 1-1005,1025-4094
set trunk 2/48 on dot1q 1-1005,1025-4094
set spantree portfast    2/28 enable
set port channel 2/28 mode off
#module 3 : 48-port 10/100BaseTx Ethernet
set vlan 10   3/1-2
set vlan 30   3/3-4
set vlan 400  3/5,3/7-48
set vlan 900  3/6
set port membership 3/48  dynamic
set trunk 3/1  on dot1q 1-1005,1025-4094
set trunk 3/2  on dot1q 1-1005,1025-4094
set trunk 3/48 off dot1q 1-1005,1025-4094
set spantree portfast    3/48 enable
set port channel 3/1-2 mode on
set port channel 3/48 mode off
3560
interface Port-channel40
 switchport trunk native vlan 10
interface GigabitEthernet0/1
 channel-group 40 mode desirable non-silent
interface GigabitEthernet0/2
Now when i try the configure a port channel between 4506 and SG300 failed, i've used on the ports 3/1-2 on the CatOS and this for SG300 but doesn't work.
SG300
interface gigabitethernet27
 channel-group 1 mode on
interface gigabitethernet28
 description portchannel-sg300
As I am getting your point there is some configuration issue.
Please check below link and read about silent or non-silent mode.
https://supportforums.cisco.com/t5/lan-switching-and-routing/pagp-silent-and-non-silent/td-p/1495264
Deepak Kumar
Deepak Kumar,
Contrary to Cat3560 with SG300 you should specify Vlans permitted within a trunk. Will you please add these via the "switchport trunk allowed vlan add" command under the "Interface Port-Channel1". Required Vlans also need to be configured first under the "vlan database".
Best regards,
Antonin
