Etherchannel setup
PacNWNetTek
I have a Cisco 2960-X AL and a 3850-XS 10G SFP+. I have added an etherchannel bundle of 2 interfaces on both switches and the port-channel is up. The goal is to increase the throughput capability of the 2960-X. My question is, as the ports say they're up/connected on both switches, on the 3850 itself the lights are flashing amber. Is there some error im missing? Or is this normal? The following is my etherchannel detail out and logs.
Switch#sho etherchannel deta
Channel-group listing:
Group: 1
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Te1/0/23
Port state = Up Mstr Assoc In-Bndl
Channel group = 1 Mode = Active Gcchange = -
Port-channel = Po1 GC = - Pseudo port-channel = Po1
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Te1/0/23 SA bndl 32768 0x1 0x1 0x118 0x3D
Partner's information:
Port Flags Priority Dev ID Age key Key Number State
Te1/0/23 SA 32768 00d6.febe.0200 5s 0x0 0x1 0x11D 0x3D
Age of the port in the current state: 0d:00h:29m:24s
Port: Te1/0/24
Local information:
Te1/0/24 SA bndl 32768 0x1 0x1 0x119 0x3D
Te1/0/24 SA 32768 00d6.febe.0200 12s 0x0 0x1 0x11C 0x3D
Port-channels in the group:
Port-channel: Po1 (Primary Aggregator)
Age of the Port-channel = 0d:01h:15m:33s
Logical slot/port = 12/1 Number of ports = 2
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Te1/0/23 Active 0
0 00 Te1/0/24 Active 0
Time since last port bundled: 0d:00h:29m:24s Te1/0/23
Time since last port Un-bundled: 0d:00h:30m:00s Te1/0/24
Switch#sho logging
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 98 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 98 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
File logging: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 100 message lines logged
Logging Source-Interface: VRF Name:
Log Buffer (4096 bytes):
ED: Interface TenGigabitEthernet1/0/24, changed state to administratively down
*Jul 2 17:13:09.737: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to down
*Jul 2 17:13:09.742: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/24, changed state to down
*Jul 2 17:13:33.136: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:13:33.139: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/24, changed state to up
*Jul 2 17:13:34.389: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:13:34.486: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/24, changed state to up
*Jul 2 17:13:35.387: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
*Jul 2 17:13:36.388: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
*Jul 2 17:13:57.232: %SYS-5-CONFIG_I: Configured from console by console
*Jul 2 17:17:32.556: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to down
*Jul 2 17:17:33.560: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to down
*Jul 2 17:17:41.629: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:17:44.312: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:22:02.261: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
*Jul 2 17:22:03.253: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/23, changed state to administratively down
*Jul 2 17:22:03.260: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/24, changed state to administratively down
*Jul 2 17:22:03.262: %LINK-3-UPDOWN: Interface Port-channel1, changed state to down
*Jul 2 17:22:04.253: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to down
*Jul 2 17:22:04.259: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/24, changed state to down
*Jul 2 17:22:26.646: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:22:26.649: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/24, changed state to up
*Jul 2 17:22:27.962: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/24, changed state to up
*Jul 2 17:22:28.961: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
*Jul 2 17:22:29.798: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:22:29.961: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
*Jul 2 17:24:29.918: %SYS-5-CONFIG_I: Configured from console by console
*Jul 2 17:57:45.801: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
*Jul 2 17:57:46.791: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/23, changed state to administratively down
*Jul 2 17:57:46.799: %LINK-5-CHANGED: Interface TenGigabitEthernet1/0/24, changed state to administratively down
*Jul 2 17:57:46.801: %LINK-3-UPDOWN: Interface Port-channel1, changed state to down
*Jul 2 17:57:47.791: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to down
*Jul 2 17:57:47.799: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/24, changed state to down
*Jul 2 17:58:20.233: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:58:20.238: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/0/24, changed state to up
*Jul 2 17:58:23.200: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/23, changed state to up
*Jul 2 17:58:23.232: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/0/24, changed state to up
*Jul 2 17:58:24.198: %LINK-3-UPDOWN: Interface Port-channel1, changed state to up
*Jul 2 17:58:25.198: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
*Jul 2 18:08:58.526: %SYS-5-CONFIG_I: Configured from console by console
16 Replies 16
balaji.bandi
Make sure you have right optic both the side, Seconds there are some bugs in 3850 so uplift the IOS.
BB
Optics are the same, 1GB SFP (same brand) both ends, tested with multi-mode and single mode LC to LC cabling. based on the fact it does the same thing on another 10GB switch i think a bug is my issue.
