Facing issue with POE for WS-X4648-RJ45V+E module on 4500
vinod.mali
                 Hi guys,
My peo module  WS-X4648-RJ45V+E i on 4506 is getting faulty i.e  the desktops are getting connected but the module is not able to deliver power to the ip phone.
I tried and replaced the module  but it worked for  some time and again got faulty.This way my three modules have gone faulty even I tried and changed the slot but no results.
I am not able to trace out whether this issue is with some phones connected on the moudle.
thing is the show power commands o/p seems to be normal, once the power over limit logs are getting generated prior to the failure of POe on the module.
19 Replies 19
p.mcgowan
Level 3
Level 3
how many power devices have you connected to the line card?
what type of phones are you trying to connect?
the WS-X4648-RJ45V+E supports up to 30W of inline power per port on up to 24 ports simultaniously.
Can you post the errors which are generated in the logs?
I have the exact same issue and Cisco Tac has not been able to identify the issue. I am going to replace my second module in the space of 2 weeks.
My issue has been that some ports are ok and some just stop delivering power on the module. I found out that the line card is divided into 6 ASICS with 8 ports each. On the previous module I had issues with 16 ports (Fa3/32 - 48) pointing to the last two ASICS being bad. On the current module I have an issue on 8 ports (Fa3/16 - 23). Looking at the module it does not show any signs of any issue. Show tech does not indicate any issues either, all I see are phones rebooting and the interface showing 0v for inline power.
My next step is to move this module to a different slot and see if the problem follows....
Leo Laohoo
Try this:
1.  Command:  test cable tdr interface ;
2.  Wait for approximately 61 seconds (takes longer on the line cards of the 4500/6500 as compared to the supervisor card);
3.  Command:  sh cable tdr interface ; and
4.  Post the output.
Just checking if someone else has been facing this issue very frequently on C4507R-E / 12.2(54)SG1 / X4648-RJ45V-E
Oct 31 00:42:59.573 UAE: %C4K_IOSMODPORTMAN-4-INLINEPOWEROVERWARNING: Module 6 inline power exceeds threshold: status changed to 'Pwr Over'
After which the ports go down and line card reseat/reset fixes the problem.
We had checked with TAC, as per the engineer this suspects to a problem on the PoE daughter card on the line card, suggesting a replacement, but we had replaced almost 2 different line cards. This issue is still appearing on different switches.
Akhtar
vinod.mali
Almost about 40 avaya Ip phones are connected on the module.
folowing errors are generated for the module
INLINEPOWEROVERWARNING: Module 2 inline power exceeds threshold: status changed to 'Pwr Over'
INLINEPOWEROK: Module 2 inline power within limits: status changed to 'Ok'
find attached sh tech
This problem could eb related to a known bug, are you also using 1400W power supplies?
Inline power exceeds threshold:Module status changed to 'Pwr Over'
This message indicates that the measured PoE is higher than the  configured value. The switch has either misconfigured PoE or an  unauthorized powered device that is connected to the switch and is drawing a  lot of PoE. In installations with a 1400 W DC power supply, this warning can  be a false positive.
Recommended Action:
You can use the show power detail command and  keyword or the show module command to compare the adminstrative  (configured) power (measured) consumption to the operating power  consumption. Verify that PoE is set correctly and that no unauthorized  powered devices are connected to the switch. For more information, refer to  bug ID CSCef49715.
bugID - CSCef49715;
Symptom
Catalyst 4500 with 1400 DC power supply may report "Pwr Over" or "Pwr Fault"
status for the following modules
- WS-X4248-RJ45V
- WS-X4248-RJ21V
- WS-X4548-GB-RJ45V
The following logging messages may also be generated
%C4K_IOSMODPORTMAN-4-INLINEPOWEROVERWARNING: Measured inline power higher than
configured value
%C4K_IOSMODPORTMAN-2-INLINEPOWEROVERCRITICAL: Measured inline power exceeds
module limit
Condition:
The above symptoms are typically generated if one of the PoE devices connected
to the module is drawing more power than it should. Make sure the connected
devices are not drawing more power than expected. However, in systems using
1400W DC power supplies, it is also possible that due to an anomaly in the
measuring mechanism in these linecards, the messages and associated status are
erroneously displayed. There is NO functionality/performance impact due to this
condition. The modules are safe and would have no impact to the operation of the
switch or the connected PoE devices.
Troubleshooting steps:
This situation may be caused by a device that is using more inline power than
allocated. Please make sure that the right amount of inline power has been
allocated to each device. If the inline power allocation is correct, start
pulling out one device at a time and see if the power usage decreases as
expected. (You can use the command, "#show power detail" to see the inline
power allocated to the module (admin) and the inline power used (operating).)
If the "inline power used" decreases sharply when a device is disconnected,
chances are that this device is using more inline power than allocated.
Avoiding using this device should solve your problem.
If after disconnecting all the devices on the module, the inline power usage
is still high, and the system does not use 1400W DC power, call TAC.
Workaround
On 1400W DC powered systems, this is a cosmetic problem but here are the
workarounds
- If this happens with PWR-C45-1400DC-P (DC power supply), using
other type of power supplies (e.g. AC power supply) would avoid this problem
- To prevent this from happening with this combination of Power Supply and
Linecards, make sure to insert the modules atleast after about 1 second after
the 12v (data) and 48v (inline power) power supply switches has been turned
on. In other words, power cycle the switch without these linecards in the
chassis and insert them once the switch is powered up.
If this message is seen on a system with 1400W DC power, please refer to the
steps mentioned in "Recommended Action".
Recommended action:
1. Collect the output of "show power detail".
2. Contact TAC to open case and attach the above output.
3. In agreement with TAC, please raise an RMA from Mfg-new and EFA the board.
Please rate the post if helpful
I have gone through this bug, unfortunately the switch is not using the 1400 w ppwer supply.
Have you tried the TDR?
the tdr testing is planned in weekend will update you with the o/ps
We have been also hit by this problem. The switch(C4507R-E / 12.2(54)SG1) is having 4200ACV PS so the bug CSCef49715 doesn't apply to our case also.
We observed that all the ports on module-1(X4648-RJ45V-E) had 0W (Power from PS and Power to device), all desktops were fine only phones were affected.
We had tried hw-module reset to recover from this problem.
Just wondering if any one has found out a root cause for this problem ?
show power detail
Power                                             Fan       Inline
Supply  Model No          Type       Status       Sensor    Status
PS1     PWR-C45-4200ACV   AC 4200W   good         good      good
PS1-1                         220V   good
PS1-2                         220V   good
PS2     PWR-C45-4200ACV   AC 4200W   good         good      good
PS2-1                         220V   good
PS2-2                         220V   good
Power supplies needed by system    : 1
Power supplies currently available : 2
Power Summary                      Maximum
(in Watts)              Used     Available
System Power (12V)       1040        1360
Inline Power (-50V)       878        3120
Backplane Power (3.3V)     40          40
Total                    1958 (not to exceed Total Maximum  Available = 4200)
Power Measurement    Inline Power (-50V)
(in Watts)             (+/- 50Watts)
PS1                         300
PS2                         250
Total                       550
                             Watts Used of System  Power(12V)
Mod   Model                 budgeted instantaneous  peak    out of reset  in reset
1    WS-X4648-RJ45V-E          92         --         --         92          10
2    WS-X4648-RJ45V-E          92         --         --         92          10
3    WS-X45-SUP6-E            260         --         --        260         260
4    WS-X45-SUP6-E            185         --         --        185         185
5    WS-X4648-RJ45V-E          92         --         --         92          10
6    WS-X4648-RJ45V-E          92         --         --         92          10
7    WS-X4648-RJ45V-E          92         --         --         92          10
--   Fan Tray                 135         --         --        --          --
       Total                  1040         --         --        905         495
                        Watts used of Chassis Inline Power  (-50V)
                        Inline Power Admin  Inline Power  Oper
Mod   Model                PS     Device       PS      Device     Efficiency
1    WS-X4648-RJ45V-E        89       82         68        63          93
2    WS-X4648-RJ45V-E       200      186        157       146          93
3    WS-X45-SUP6-E            -        -          -         -           -
4    WS-X45-SUP6-E            -        -          -         -           -
5    WS-X4648-RJ45V-E       258      240        176      163           93
6    WS-X4648-RJ45V-E       203      189        135       126          93
7    WS-X4648-RJ45V-E       128      119         99        92          93
       Total                 878      816        635       590
Switch Logs:
Sep  5 12:50:07.124 UAE:  %C4K_IOSMODPORTMAN-4-INLINEPOWEROVERWARNING: Module 1 inline power exceeds  threshold: status changed to 'Pwr Over'
Sep  5 12:50:08.072 UAE: %LINEPROTO-5-UPDOWN: Line protocol  on Interface GigabitEthernet1/3, changed state to down
Sep  5 12:50:08.072 UAE: %LINEPROTO-5-UPDOWN: Line protocol  on Interface GigabitEthernet1/21, changed state to down
Sep  5 12:50:08.076 UAE: %LINEPROTO-5-UPDOWN: Line protocol  on Interface GigabitEthernet1/34, changed state to down
Sep  5 12:50:08.076 UAE: %LINEPROTO-5-UPDOWN: Line protocol  on Interface GigabitEthernet1/44, changed state to down
Sep  5 12:50:08.852 UAE: %LINK-3-UPDOWN: Interface  GigabitEthernet1/47, changed state to down
Sep  5 12:50:08.856 UAE: %LINK-3-UPDOWN: Interface  GigabitEthernet1/39, changed state to down
Sep  5 12:50:09.188 UAE: %C4K_IOSMODPORTMAN-6-INLINEPOWEROK:  Module 1 inline power within limits: status changed to 'Ok'
Sep  5 12:50:09.188 UAE: %C4K_IOSMODPORTMAN-6-MODULEONLINE:  Module 1 (WS-X4648-RJ45V-E S/N: JAE12067KBJ Hw: 1.0) is online
Akhtar
Hi vinod,
I 'm having the same problem with 4506E switch with cat4500e-entservicesk9-mz.122-54.SG.bin, and line cards
WS-X4648-RJ45V+E.
something weird because the ports that have problems are in card # 3, and the number of ip phones is  low
Did you clear this issue??
SW_CORE#sh power inline module 2
Available:796(w)  Used:299(w)  Remaining:497(w)
Interface Admin  Oper            Power(Watts)     Device              Class
                            From PS    To Device
Gi2/1     auto   off        0.0        0.0        n/a                 n/a
Gi2/2     auto   on         12.9       12.0       IP Phone 7945       3
Gi2/3     auto   on         12.9       12.0       IP Phone 7945       3
Gi2/4     auto   on         6.8        6.3        IP Phone 7942       2
Gi2/5     auto   off        0.0        0.0        n/a                 n/a
Gi2/6     auto   on         6.8        6.3        IP Phone 7942       2
Gi2/7     auto   off        0.0        0.0        n/a                 n/a
Gi2/8     auto   off        0.0        0.0        n/a                 n/a
Gi2/9     auto   off        0.0        0.0        n/a                 n/a
Gi2/10    auto   off        0.0        0.0        n/a                 n/a
Gi2/11    auto   on         6.9        6.4        IP Phone 8945       2
Gi2/12    auto   off        0.0        0.0        n/a                 n/a
Gi2/13    auto   on         6.8        6.3        IP Phone 7962       2
Gi2/14    auto   on         6.8        6.3        IP Phone 7942       2
Gi2/15    auto   on         6.8        6.3        IP Phone 7942       2
Gi2/16    auto   on         6.8        6.3        IP Phone 7942       2
Gi2/17    auto   on         6.5        6.0        IP Phone 6921       2
Gi2/18    auto   on         6.8        6.3        IP Phone 7942       2
Gi2/19    auto   off        0.0        0.0        n/a                 n/a
Gi2/20    auto   on         6.8        6.3        IP Phone 7962       2
Gi2/21    auto   on         6.9        6.4        IP Phone 8945       2
Gi2/22    auto   off        0.0        0.0        n/a                 n/a
Gi2/23    auto   off        0.0        0.0        n/a                 n/a
Gi2/24    auto   on         6.9        6.4        IP Phone 8945       2
Gi2/25    auto   off        0.0        0.0        n/a                 n/a
Gi2/26    auto   off        0.0        0.0        n/a                 n/a
Gi2/27    auto   on         6.9        6.4        IP Phone 8945       2
Gi2/28    auto   off        0.0        0.0        n/a                 n/a
Gi2/29    auto   on         6.8        6.3        IP Phone 7942       2
Gi2/30    auto   on         6.5        6.0        IP Phone 6921       2
Gi2/31    auto   on         6.9        6.4        IP Phone 8945       2
Gi2/32    auto   off        0.0        0.0        n/a                 n/a
Gi2/33    auto   on         6.8        6.3        IP Phone 7962       2
Gi2/34    auto   off        0.0        0.0        n/a                 n/a
Gi2/35    auto   off        0.0        0.0        n/a                 n/a
Gi2/36    auto   on         6.5        6.0        IP Phone 6921       2
Gi2/37    auto   on         6.5        6.0        IP Phone 6921       2
Gi2/38    auto   on         6.5        6.0        IP Phone 6921       2
Gi2/39    auto   off        0.0        0.0        n/a                 n/a
Gi2/40    auto   off        0.0        0.0        n/a                 n/a
Gi2/41    auto   off        0.0        0.0        n/a                 n/a
Gi2/42    auto   off        0.0        0.0        n/a                 n/a
Gi2/43    auto   off        0.0        0.0        n/a                 n/a
Gi2/44    auto   off        0.0        0.0        n/a                 n/a
Gi2/45    auto   on         16.6       15.4       AIR-LAP1262N-N-K9   3
Gi2/46    auto   on         16.6       15.4       AIR-LAP1262N-N-K9   3
Gi2/47    auto   on         16.6       15.4       AIR-LAP1262N-N-K9   3
Gi2/48    auto   on         16.6       15.4       AIR-LAP1262N-N-K9   3
Totals:          26   on    226.5      210.6
SW_CORE#sh power inline module 3
                            From PS    To Device
Gi3/1     auto   off        0.0        0.0        n/a                 n/a
Gi3/2     auto   off        0.0        0.0        n/a                 n/a
Gi3/3     auto   on         6.5        6.0        IP Phone 6921       2
Gi3/4     auto   off        0.0        0.0        n/a                 n/a
Gi3/5     auto   off        0.0        0.0        n/a                 n/a
Gi3/6     auto   off        0.0        0.0        n/a                 n/a
Gi3/7     auto   on         6.5        6.0        IP Phone 6921       2
Gi3/8     auto   on         6.5        6.0        IP Phone 6921       2
Gi3/9     auto   off        0.0        0.0        n/a                 n/a
Gi3/10    auto   off        0.0        0.0        n/a                 n/a
Gi3/11    auto   off        0.0        0.0        n/a                 n/a
Gi3/12    auto   off        0.0        0.0        n/a                 n/a
Gi3/13    auto   on         6.9        6.4        IP Phone 8945       2
Gi3/14    auto   off        0.0        0.0        n/a                 n/a
Gi3/15    auto   off        0.0        0.0        n/a                 n/a
Gi3/16    auto   off        0.0        0.0        n/a                 n/a
Gi3/17    auto   on         6.9        6.4        IP Phone 8945       2
Gi3/18    auto   off        0.0        0.0        n/a                 n/a
Gi3/19    auto   off        0.0        0.0        n/a                 n/a
Gi3/20    auto   on         6.8        6.3        IP Phone 7942       2
Gi3/21    auto   off        0.0        0.0        n/a                 n/a
Gi3/22    auto   off        0.0        0.0        n/a                 n/a
Gi3/23    auto   off        0.0        0.0        n/a                 n/a
Gi3/24    auto   off        0.0        0.0        n/a                 n/a
Gi3/25    auto   on         6.5        6.0        IP Phone 6921       2
Gi3/26    auto   off        0.0        0.0        n/a                 n/a
Gi3/27    auto   off        0.0        0.0        n/a                 n/a
Gi3/28    auto   off        0.0        0.0        n/a                 n/a
Gi3/29    auto   on         6.5        6.0        IP Phone 6921       2
Gi3/30    auto   off        0.0        0.0        n/a                 n/a
Gi3/31    auto   on         6.8        6.3        IP Phone 7942       2
Gi3/32    auto   off        0.0        0.0        n/a                 n/a
Gi3/33    auto   off        0.0        0.0        n/a                 n/a
Gi3/34    auto   off        0.0        0.0        n/a                 n/a
Gi3/35    auto   off        0.0        0.0        n/a                 n/a
Gi3/36    auto   off        0.0        0.0        n/a                 n/a
Gi3/37    auto   off        0.0        0.0        n/a                 n/a
Gi3/38    auto   off        0.0        0.0        n/a                 n/a
Gi3/39    auto   off        0.0        0.0        n/a                 n/a
Gi3/40    auto   on         6.9        6.4        IP Phone 8945       2
Gi3/41    auto   on         6.5        6.0        IP Phone 6921       2
Gi3/42    auto   off        0.0        0.0        n/a                 n/a
Gi3/43    auto   off        0.0        0.0        n/a                 n/a
Gi3/44    auto   off        0.0        0.0        n/a                 n/a
Gi3/45    auto   off        0.0        0.0        n/a                 n/a
Gi3/46    auto   off        0.0        0.0        n/a                 n/a
Gi3/47    auto   off        0.0        0.0        n/a                 n/a
Gi3/48    auto   off        0.0        0.0        n/a                 n/a
Totals:          11   on    72.9       67.8
SW_CORE#
SW_CORE#sh power mo
SW_CORE#sh power module
t
1    WS-X45-SUP6L-E           200         --        --        200         200
2    WS-X4648-RJ45V+E          92         --        --         92          10
3    WS-X4648-RJ45V+E          92         --        --         92          10
--   Fan Tray                 120         --        --        --          --
       Total                   504         --        --        384         220
1    WS-X45-SUP6L-E           -        -          -        -           -
2    WS-X4648-RJ45V+E       226      211        117      109          93
3    WS-X4648-RJ45V+E        73       68         44       40          93
       Total                 299      279        161      149
SW_CORE#
vinitkale123
I am facing similar kind of issue with 4510R+E switch.Model is  WS-C4510R+E.
Is there any fix for this.Power seems normal to the switch as well
Hi Vinit,
In my case I clear this issue after applying the command ( for the module with problem)
hw-module module 3 reset
regards
I would do a hardware reset , reseat and if both don't work...engage Cisco TAC and get it replaced.
Sent from Cisco Technical Support Android App
