Firewall & Switches
sachinc01
Dear Sir,
I have following device ASA5508-FPWR-BUN X 1No
Catalyst 9300 48-port PoE+ X 3Switches now I want to configured 2 IP scope & DHCP for both IP scope on firewall & on the switch  2 VLAN .
On the Firewall I have configured 2 LAP IP (192.168.1.X,172.16.16.X)& also DHCP scope & firewall both cable connect to switch port 24 & 45, 46 -48 are the trunk port to connect another switches.
now on the switch I have configured 2 VLAN 172 & 192 port 1-24 port for 172 VLAN 24-45 port for 192 vlan.
I able to get DHCP & working but i have get both range ip through LAN or wifi which i not need i need only 192 scope for use & 172 range for CCTV only.
Can some one guide which configuration i will need or what changes i will need.........
balaji.bandi
as long as the en device connected to right access port they get respectected DHCP client IP.
can you post switch config. tell use where the cctv and other devices connected.
BB
