Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 16460 Views
  • 36 replies
  • 2 Helpful votes
I have a stack of 4 C9200L-48P-4X switches running 17.09.05 cat9_lite_iosxe which I cant upgrade.I tried copying the 17.18.04 to flash: but cant install due to insufficient memory.Now I put a usb drive in the switch and ran: install add file ...activ...
Nout by • Level 1
  • 193 Views
  • 12 replies
Hey!Cisco Catalyst 9300 L2 guide explicitly states that ptp mode:"Specifies the synchronization clock mode: - boundary: to enable the switch to participate in selecting the best master clock. If no better clocks are detected, the switch becomes the g...
rootswitch by • Frequent Visitor
  • 91 Views
  • 0 replies
I bought a Cisco Catalyst switch from a hamfest (amateur radio swap meet) and am trying to get it working.  I am a retired software engineer and am just looking to get this working.  I can connect to it through a serial conection and can run some ini...
Hi, So I've bought a second hand Cisco SG350-28, however I just found out on the switch the reset button is broken off the mainboard, I'm wondering if there's any way to get a replacement or if there might be some tips about DIY'ing it.
jorianb by • Community Member
  • 140 Views
  • 3 replies
Resolved! MACsec and MTU
Hey!The Cisco guideline "Troubleshoot MACsec on Catalyst 9000" recommends to increase the system  MTU to accomodate for extra 32 bytes due to MACsec. However, on Catalyst 9300 I do not see any packet being drppped when using max packet size (macsec e...
  • 274 Views
  • 5 replies
Hi Guys, I have a network consisting of a L3 3560, 2960's and HP 2650's in a loop. When connecting a new machine up it can take quite a while to get an IP address, I understand this is due to the switch port 'listening' for 30 or so seconds? Is it po...
tomsund11 by • Community Member
  • 2138 Views
  • 7 replies
Hey!Assume this scenario. Switch A and switch B are linked by a trunk encrypted with MACsec. According to Cisco security guide "RSPAN or ERSPAN does not capture encrypted packets at egress and decrypted packets at ingress for MACsec enabled interface...
  • 211 Views
  • 4 replies
Hello,I have a question regarding bug CSCuz24063.Due to the impact of CSCuz24063, is it possible for the running configuration to be modified automatically when a member port experiences a link down/up event, such as when the cable is unplugged and p...
i have a 3850 stack of 2 switches in my mdf.  i have another switch in my idf connected by fiber.  everything has been good for years.  i just added another 3850 switch into my stack in my mdf.  now i cant access by idf switch at all.  cant ping or p...
  • 16460 Views
  • 36 replies
  • 2 Helpful votes
I would appreciate any help with this.I am trying to find the last image pushed by cisco. I know this is an extremely old piece of equipment, but I have it and would like to use it for a home lab. The most recent post on here says the file name would...
remfire10 by • Community Member
  • 171 Views
  • 2 replies
