Help finding appropriate ethernet switch
We are currently using stacks of SG-200-8 switches in a product we ship to our customers. We are going to be changing our architecture such that we need switches with the following capabilities:
1) 12-24 gigabit Ports
2) At least 8 of the ports need to be POE.
3) We need a local interface on the switch that will allow us to control the power on/off status of individual POE ports.
4) We do not "need" to have any other management capabilities.
Appreciate any advice or recommendations.
you can use below switches.
1. CBS350-16P-2G with 120W PoE budget for 16 ports. capable to provide PoE for 8 (15W) devices or matching devices up to 120W (supports PoE+)
2. CBS350-16FP-2G with 240W PoE budget for 16 ports.  capable to power 16 (15W) devices or matching devices up to 240W (supports PoE+) this model is preferred to avoid PoE budget mismatches.
datasheet - https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html#Orderinginformation
good luck. mark this as answer and rate if this completed your concerns.
KB
Good luck
KB
10 Replies 10
balaji.bandi
it all depends on the budget if you looking for small business switches :
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
If you looking enterprise-grade :
Cat 1000  Cat 9200 is a good candidate.
https://www.cisco.com/c/en_uk/products/switches/campus-lan-switches-access/index.html#~products
BB
Thank you for the link. Just to be more specific, each of our "private networks" uses TCP to communicate to/from a HOST PC all using fixed IPV4 addresses. There is no external connection to the "internet". By what mechanism would the HOST PC be able to enable or disable POE on a specific port while running (not during initial setup). Could you point me to any resources on how to implement this?
Thanks again.
it is a bit unclear what you are trying to achieve. What exactly do you need, a management PC ? Any connected PC can be used for management (and turning off/on PoE), as long as the switch has a management IP address configured (which it usually does),...
Georg, Thank you for your response. Currently we are using groups of 3 SG-200-8 switches. We do not use any of their management capabilities. We spend zero time configuring them. We are going to move to a POE design and will need to be able to manage whatever new switch we have to turn on/off POE in real time. I am unfamiliar with configuring and using the management IP address. So I assume then that if one has a management IP address, one could use some sort of command line interface to "talk" to the switch and control POE state (for instance)? Where would I find documentation on exactly what "commands" one might use to accomplish this? Thanks again.
I see that some of the 300 series switches that were included in the original link are now obsolete (SG300-20 for instance).
I now have a better understanding of my switch needs:
1) 16 POE ports or 8 POE ports + 8 non POE ports
2) POE = class 3
3) Ports are gigabit ethernet
4) Switch can be managed with a CLI via a local cable connection (Serial/USB) to a local PC.
Does Cicso have anything that supports these requirements?
KB
Good luck
KB
We have ordered and received a CBS350-16P-2G for evaluation.
Can you recommend any resources for working with the command line interface to configure and control this switch? From the basic documentation with the switch I see the web/browser interface information, but I do not see any information for the db9/serial interface/command line interface.
Thanks!
below is a link to all CLI commands available on that model...
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-.html
Much appreciated!
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/solutions/small-business/selector-tool.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
