Help Required - Lab Setup Routing
I am in the process of setting up a vocie lab.
I have three networks
172.16.1.0(Voice) - def gateway 172.16.1.1
172.16.2.0(Data) - def gateway 172.16.2.1
172.16.3.0(management vlan)
created in a 2621XM through dhcp pool.
I have the IP Phones hooked up to the Voice network 172.16.1.0 (Vlan 10) and a deskop in 172.16.2.0 ( vlan 50).  The IP Phones just work fine having registed with the CME (172.16.1.1)
I can ping the router 172.16.2.1 from the server 172.16.2.11 and vice versa.
I am not able to ping the other network 172.16.1.0 from the Server (172.16.2.11).
Please help. Thanks for your invaluable time.
6 Replies 6
p.mcgowan
Level 6
Level 6
can you please post config of router
show run
thanks
Vivek V
Please  check if the SVI 2.1(source ping) is able to ping the SVI's of the other networks .
If this is successfull, please try a source ping to the end devices in the other vlans.
If the above mentioned case is occurring , one of these will fail.
Depending on this , we can decide whether it is a routing issue or some other config.
(please attach config as well)
/ Vivek
have you set a default gateway on your server 172.16.2.11 to point it to 172.16.2.1?
Please remember to rate useful posts, by clicking on the stars below.
Here is router configuration.   I thank your for valuable time....
VOICE_GATEWAY#show run
Building configuration...
Current configuration : 2026 bytes
version 12.4
hostname VOICE_GATEWAY
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.1 172.16.1.10
ip dhcp excluded-address 172.16.2.1 172.16.2.10
ip dhcp pool VOICE
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   dns-server 4.2.2.2
   option 150 ip 172.16.1.1
ip dhcp pool DATA
   network 172.16.2.0 255.255.255.0
   default-router 172.16.2.1
no ip domain lookup
ip host SW1 172.16.3.2
vlan internal allocation policy ascending
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.3.1 255.255.255.0
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 172.16.1.1 255.255.255.0
interface FastEthernet0/0.50
encapsulation dot1Q 50
ip address 172.16.2.1 255.255.255.0
interface Serial0/0
no ip address
shutdown
no fair-queue
router eigrp 109
network 172.16.0.0
auto-summary
ip http server
no ip http secure-server
control-plane
voice-port 1/0/0
voice-port 1/0/1
telephony-service
max-ephones 10
max-dn 10
ip source-address 172.16.1.1 port 2000
auto assign 1 to 5
auto assign 1 to 5 type 7940
max-conferences 4 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 1001
name Jason
ephone-dn 2 dual-line
number 1002
name Jensy
ephone 1
mac-address 0017.9538.84D9
type 7940
button 1:1
ephone 2
mac-address 0013.C44A.7CC0
type 7940
button 2:2
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
VOICE_GATEWAY#
can you do extended ping to 172.16.2.1 with a source address of 172.16.1.1?
If you are unfamiliar with extended ping please look at link below for full explanation
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093f22.shtml
have you checked the default gateway of the sever (172.16.2.11) is this set for 172.16.2.1?
Hi mcgowan,
Thanks for the response.
I checked the extended ping and I am able to do extended ping successfully from Source 172.16.1.1 to Target 172.16.2.1 but not to Target 172.16.2.11.... Do you think this is something to do with my desktop ? I have added exceptions in such a way to allow router requests to be accepted in the windows firewall(ICMP) in the desktop. Pls help
Thanks mate for your time....
