intervlan routing in layer 3 switch
vishalpatil86
hi,
can anyone tell me, how can I configure inter vlan routing in layer 3 switch(cisco 4506 E).
Also, I want to enable access list. I need help on this one also
6 Accepted Solutions
andrew.prince
Level 10
Level 10
To enable inter VLAN routing - create and SVI for the VLANs you want to pass IP traffic between.
HTH>
also, make sure that "ip routing" is enabled.
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
The inter VLAN routing, this will be done by your Catalyst 4506.
The main steps configuring VLANs and the inter VLAN routing are:
1.Define the VLANs
To create a VLAN named Desktop, run the following commands in privileged mode,
#conf t
#vlan 40
#name Desktop
#exit
2. Add the switch ports to previusly created VLANs
Exp: Fa0/2 to Desktop VLAN
#conf t
#int fa0/2
#switchport mode access
#switchport access vlan 40
#exit
3.Create a Layer 3 (SVI) interface for eatch VLAN
#conf t
#interface vlan 40
#ip address 192.168.0.1 255.255.255.0
#no shutdown
#exit
4. For Internet access, add a default route to the routing table
#conf t
#ip route 0.0.0.0 0.0.0.0 192.168.12.1
where 192.168.12.1 is the IP of your Inernet gateway.
Regarding access-list on 4506:
Say you want setup up below two external and one internal networks on a Catalyst 4506.
Internal Network:  VLAN1 -  172.16.0.0/16
External Network: VLAN2 - 10.138.56.79/24
                 VLAN3 - 10.138.58.161/28
Now you want prevent the two external networks from talking to the internal networks.
#access-list 101 deny 10.138.56.79 0.0.0.255 172.16.0.0 0.0.255.255
#access-list 101 permit 10.138.56.79 0.0.0.255 any
#access-list 102 deny 10.138.58.161 0.0.0.15 172.16.0.0 0.0.255.255
#access-list 102 permit 10.138.58.161 0.0.0.15 any
#interface VLAN2
#ip access-group 101 in
#interface VLAN3
#ip access-group 102 in
Please rate the all helpfull posts.
Naidu.
Did you read the link I posted above?
Did you do a #no shut    on the SVI?
ebenav11
The physical interface have any platform or end device connectedbecause if the physical interface is not operating "protocol" the logical interface is not active.
11 Replies 11
andrew.prince
Level 10
Level 10
HTH>
Looks like you got some reading to do.
Here's a good start:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
Ian
1.Define the VLANs
#conf t
#vlan 40
#name Desktop
#exit
#conf t
#int fa0/2
#exit
#conf t
#interface vlan 40
#no shutdown
#exit
#conf t
#interface VLAN2
#interface VLAN3
Naidu.
how to create new vlan in 4506 switch?
i have created vlan, but status abd protocol are showing down
hi,
i have configured dhcp also which assigns IP 10.5.5.50/24 range to clients connected thru any vlan praeviously.
Now, wat wud be the configuration if enable intervlan routing?
ebenav11
its working
Hi Vishal,
Glad that your issue is resolved.
Please click on the correct answer of all the helped posts which will encourage others.
Naidu.
