help with 4500m router
djimmy1979
Hey guys, On the 4500m router it has the old db25 female connector for the console port. Can you guys tell me if this cable will work, it appears to be a db25male to db9 female cable
http://www.bestbuy.com/site/olspage.jsp?skuId=7002986&type=product&productCategoryId=pcmcat33400050027&id=1099391933085
Jimmy
mrmozaffari
Hi jimmy
yes thats right db25 male to db9 female ,you can use external modem's cable.
Mozaffari.
s.conway
I don't know if it will work. You can find a console kit on eBay for less money.
mrmozaffari
Hi jimmy
Mozaffari.
Worked like a charm, Thanks.
k-kriegel
The Cisco adapter would be your best bet.
The RJ-45-to-DB-25 female DTE adapter is a kit (part number ACS-DSBUASYN=) containing this adapter from Cisco.
Then use it with the "baby blue" rollover ribbon cable.
