Bookmark
Subscribe
5518
Jumbo and Output errors at the TX on Nexus 5596
We are observing huge increase in Jumbo and Output errors at the TX on one of ourNexus 5596 switch.
Do we have any specific reason and what will be the soulution to fix this?
Please find the interface output.
Ethernet1/24 is up
Dedicated Interface
  Belongs to Po324
  Hardware: 1000/10000 Ethernet, address: 547f.eefb.ff9f (bia 547f.eefb.ff9f)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 2week(s) 5day(s)
  Last clearing of "show interface" counters 01:02:11
  30 seconds input rate 280 bits/sec, 0 packets/sec
  30 seconds output rate 35339936 bits/sec, 7590 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 8.32 Mbps, 633 pps; output rate 33.49 Mbps, 7.35 Kpps
  RX
    1577334 unicast packets  186 multicast packets  4280 broadcast packets
    1581800 input packets  990139607 bytes
    540658 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    27130970 unicast packets  1166 multicast packets  26407 broadcast packets
    27158543 output packets  15956581601 bytes
    7231723 jumbo packets
    260 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
  0 interface resets
Richard Michael
Hi Senthil,
What interface is the Ethernet 1/24? Is it a part of the FEX port-channel? If yes, VNTAG header addition might show there as jumbo packets the extra 6 byte.
If not, then understand why you receive a frame more than 1500 bytes. you might also try enabling the jumbo frame,
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b44116.shtml
Ricky Micky
*Rate if its useful
Kanes Ramasamy
Hi Senthil,
Have you managed to solve this issue? I seem to be having the same problem?
Could you share your outcome?
Thanks and most appreciated,
Kanes.R
