Bookmark
Subscribe
10056
Maximum number of switches in a stack?
Mark Burger
What is the maximum number of WS-C3750X-48P-S switches I can have in a stack? IOS is 12.2 (55) SE3
2 Accepted Solutions
glen.grant
Q. What is the maximum number of Cisco Catalyst 3750-X Series Switches that can make up one stack? A. Up to nine Cisco Catalyst 3750-X switches can be stacked together.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Glen aready noted, the limit is nine for data stacking (StackWise).  3750-X power stacking (Stack Power), between stack members, is limited to 4.
Also note, large 3750 stacks can sometimes be very sluggish doing some CLI commands.
And also note, although StackWise Plus supports "spacial reuse" for unicast traffic, large stacks might congest the ring sooner.
Lastly, for very large stacks, a chassis might be a better and/or less expensive solution.
6 Replies 6
glen.grant
Thank you!
Joseph W. Doherty
Disclaimer
Posting
Thanks for the info. I'm stopping at 5 switches in the stack.
Thanks again!
Leo Laohoo
Just noticed that you are running 12.2(55)SE3. I would recommend, even more true when you are using 3750/G/X, I would recommend you use 12.2(55)SE8.
Thanks for the additional information - much appreciated.
