monitoring port packets
zeitzytoun
How we can get the information presented in this image through command line (the target switch is cisco sf302-08pp)
Thanks in advance.
the CLI is limited on the SF302. Use the command:
show interfaces counters
Page 10 (Section 23) of the attached guide shows the available commands.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_Nikola300_1_3_7.pdf
6 Replies 6
marce1000
 - Try show interfaces status Gigabitethernet 1 (e.g.)
 M.
balaji.bandi
There are SMB Switches with Limited command line access : you can refer below admin guide :
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300_1_2_9.pdf
BB
thanks for your help,
I have another question, how can I get the data of Packets with Errors column  in Receive Statistics part.
show interfaces counters [interface-id | detailed
After running this command (show interfaces counters [interface-id | detailed ) we got the output as shown in the image below, can you tell us which attribute/s specifically represents Packets with Errors column.
Thanks in advance.
