03-16-2007 02:42 PM - edited 03-05-2019 02:57 PM
I'm starting a business in web hosting and ASP(email services and HR services).
I need help about the right architecture for my network. I don't want to buy bandwidth from ISP but I prefer to setup my network.. I will have about 10 servers(2 for DNS, 2 for mail, 1 for LDAP, 1 linux web hosting, 1 IIS server, 1 server for applications) and a SAN storage solution.
I need to setup my network : which router and firewall is the right for my architecture, which switch I need to buy, what is the best architecture for this : rouer, firewall, switch,10 servers.
thanks .
03-20-2007 07:10 AM
If u didnt buy bandwidth how will the outside world access u r servers..?
The equipments u need to purchase depends upon the utilization of u r services.
U need to determine what r the applications u r going to use,the bandwidth requirements of each applications etc.
Mahmood
03-20-2007 09:23 AM
don't forget ur budget
03-20-2007 01:37 PM
thanks lot for info.
please could you valide me this architecture. See the file attached.
Tazi
03-20-2007 01:42 PM
03-21-2007 04:05 AM
I forget one important thing : who can I implement the "load balancing" in my architecture ?
which hardware can I use?
03-21-2007 09:39 AM
you need to put an estimate on the traffic loads to and from your servers; you also need to determine what media your servers will connect with to the network viz 1000BaseT or 1000BaseFX. How will you terminate the tier-1 connections? same box or seperate? what type of presentation?
These will enable you select the appropriate switch/router.
03-21-2007 10:20 AM
Thanks for your help.
I think start with 20Mb/s.
For the LAN I will use 1G.
All servers, SAN, switch, load balancing switch will be in a rack in a DATACENTER.
So do you have any idea about router/firewall/switch/load balancing i need to use?
and what the right solution : 1000BaseT or 1000BaseFX ?
03-21-2007 02:26 PM
You are not realy into this technology I believe. A switch with 1000BaseT is probably what you need. Most importantly we need budget information because without we don't know if you are looking for a budget solution or better...
03-21-2007 02:36 PM
Budget about 100000$.
