Nexus 5000 - Lacp
opnineopnine
Hello
I have create a new vpc, but when I a "show port-channnel summary" why I see Po50 with Protocol NONE and 10 and 30 with Protocol LACP?
Group Port- Type Protocol Member Ports
Channel
10 Po10(SU) Eth LACP Eth116/1/2(P) Eth116/1/3(P)
30 Po30(SU) Eth LACP Eth123/1/1(P) Eth123/1/2(P)
50 Po50(SD) Eth NONE Eth2/1(D) Eth2/2(D)
Thanks.
No, even though you don't have LACP, the Portchannel operates as mode on. So, no STP issue.
10 Replies 10
Reza Sharifi
NONE usually indicates that you did not enable any protocols (in this case LACP) under the interface.
Can you post the config?
sh run int e2/1 and 2/2
sh run int po50
Also, the physical ports are currently down.
Hello
interface port-channel50
switchport mode trunk
switchport trunk allowed vlan 20
vpc 50
interface Ethernet2/1
channel-group 50
interface Ethernet2/2
channel-group 50
Thanks.
should be......channel-group 50 mode active
Hello Mark & Reza,
Thanks both for your answer, can you tell me when I have to use the different modes of lacp and with the actual configuration , can i have any spanning-tree issue?
thanks.
With Nexus, the mode is usually active/active.
As for STP, this is a Portchannel and both links logically look as one aggregated interface. So, there should not be any STP issues, as neither one of the interfaces should be blocking.
But in the case I have for the Port50 I have that lacp is not active, can I still have spanning-tree issues?
Thanks.
Yes this is right. But to do this you have to remove portchannel 50 and make for instance portchannel 40 and reasign to eth2/2 and eth 2/1
channel-group 50
This is mode on. For lacp you need to add
pafcio84
You have to crate new port-channel and then add settings again for phisical interfaces: channel group X mode active. When you see only "channel group 10" than you have status NONE. You just have to Recrate port channel.
