Nexus 5672 & Fex 2348
opnineopnine
Hi all,
I have to configure my 5672 with the fex 2348 via QSFP , I did the normal configuration but the fex is not starting up.
Is there any special configuration when I use the QSFP?
Thanks.
5 Replies 5
cn7369
Did you ever get this working?  I have the same issue and am on the verge of submitting a ticket with TAC.
Austin Sabio
Level 4
Level 4
Can you please post your uplinks config?
It should look like something like this:
feature fex
interface Po111 description UPLINK FEX-01 vpc 111 switchport mode fex-fabric fex associate 111 no shut interface Ethernet1/111 description UPLINK FEX-01 switchport mode fex-fabric fex associate 111 channel-group 111 no shut interface Ethernet1/112 description UPLINK FEX-01 switchport mode fex-fabric fex associate 111 channel-group 111 no shut
!to verify
#show fex 111 detail
If your configs are good then make sure you are using supported twinax cables or LC breakout cables.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/datasheet-c78-730760.html
I hope this helps. Good luck!
- Austin
I opened a TAC case and discovered we had the 2348TQ-E FEX modules (not the 2348TQ), which require 7.3 software to be recognized.  Once I upgraded (and power cycled the FEX's) they came online.
Excellent. Thanks for sharing your solution. I just checked that apparently 'Cisco NX-OS Release 7.3(0)N1(1) for Cisco Nexus 5500 and 5600 platforms and 6000 Series' is the minimum software requirement.
Table 2.       Cisco Nexus 2300 Platform 10 Gigabit Ethernet Fabric Extender Product Specifications
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-2000-series-fabric-extenders/datasheet-c78-731663.html
-Austin
IS VPC command is really required in port-channel configuration ?
Spoiler
