08-30-2016 02:09 AM - edited 03-08-2019 07:13 AM
I have a pair of n5k, with 10* n2k dual homed.
I have a Po for a server connected on 2 different n2k, but when I try to add vPC ID the Nexus reject my command.
NEX-A# sh port-ch sum
201 Po201(SD) Eth LACP Eth1/23(D) Eth1/24(D)
303 Po303(SD) Eth LACP Eth104/1/11(D) Eth104/1/12(D) Eth105/1/11(D)
Eth105/1/12(D)
The command works for n5k ports but not n2k :
NEX-A# sh run int po201
interface port-channel201
description SERV-00-01
switchport access vlan 112
speed 10000
vpc 201
NEX-A(config)# int po303
NEX-A(config-if)# vpc 303
ERROR: Operation failed: [vPC already exists]
Here is my show vpc, no vpc 303, but one ID per port and a total of 508 vpc whereas I configured only 2 vpc :
NEX-A# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 5
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 508
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
vPC Peer-link status
id Port Status Active vlans
1 Po1 up 8,104,112,208,297-299,490-492,560-572,580,590,2000
,2008,2104
vPC status
id Port Status Consistency Reason Active vlans
201 Po201 down* Not Consistency Check Not -
Applicable Performed
102400 Eth101/1/1 down* Not Consistency Check Not -
102401 Eth101/1/2 down* Not Consistency Check Not -
102402 Eth101/1/3 down* Not Consistency Check Not -
Can you help me ?
Solved! Go to Solution.
08-30-2016 08:21 AM
There will be an internal port-channel created for enhanced VPC. you dont need to explicitly set a VPC ID. in fact, you cant.
please check the output of "show vpc brief" and you will see the port-channel listed there.
08-30-2016 08:29 AM
Hi;
You share the output of "show vpc brief" of primary switch, can you verify on secondary N5K switch also may be vPC id 303 is assigned to port-channel.
Thanks & Best regards;
08-30-2016 03:19 AM
Hi;
Can you tell the part# of your nexus 5K, either its 5000 or 5500 Series Nexus?
08-30-2016 04:47 AM
This is N5K-C5672UP with n6000-uk9.7.0.8.N1.1 software.
08-30-2016 08:29 AM
Hi;
08-30-2016 08:21 AM
08-30-2016 08:30 AM
You're right, here is the output with auto generated ID :
111662 Eth110/1/47 down* Not Consistency Check Not -
111663 Eth110/1/48 down* Not Consistency Check Not -
262446 Po303 down* Not Consistency Check Not -
262454 Po311 down* Not Consistency Check Not -
262455 Po312 down* Not Consistency Check Not -
It's an error from my part, we need to use vPC ID on Po, when Fex are single homed.
Thank you all.
