NTP Synchronization problem 2600 router
johnramz
Cisco COmmunity:
In the below setup the CISCO 2600 router is not synchronizing with external NTP server
PLease help
John
Setup:
INTERNET ISP router ======CISCO ASA5505(10.1.1.2)======fa0/1CISCO 2600fa0/0=====Users
The goal is to synchronize the 2600 with an External NTP server. The ASA is already synchronized after using just these commands:
clock timezone UTC -6
ntp server 38.106.177.10
ON THE 2600 router I get these outputs after 3 hours:
RTR#sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18
reference time is 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
RTR#sh ntp association
      address         ref clock     st  when  poll reach  delay  offset    disp
~38.106.177.10    0.0.0.0          16     -    64    0     0.0    0.00  16000.
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
RTR# debug ntp packet
*Apr  3 18:28:01.065: NTP: xmit packet to 38.106.177.10:
*Apr  3 18:28:01.065:  leap 3, mode 3, version 3, stratum 0, ppoll 64
*Apr  3 18:28:01.065:  rtdel 0000 (0.000), rtdsp 10001 (1000.015), refid 00000000 (0.0.0.0)
*Apr  3 18:28:01.065:  ref 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
*Apr  3 18:28:01.065:  org 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
*Apr  3 18:28:01.065:  rec 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
*Apr  3 18:28:01.065:  xmt AF68AA11.10C7B7FB (18:28:01.065 CST Sat Apr 3 1993)
Configuration
RTR#sh run
Building configuration...
Current configuration : 1853 bytes
version 12.2
service timestamps debug datetime msec localtime
service password-encryption
hostname RTR
clock timezone CST -6
clock summer-time CDT recurring
ip subnet-zero
ip domain-name domain.com
ip name-server 10.250.100.1
interface FastEthernet0/0
ip address 10.250.1.113 255.255.0.0
no ip proxy-arp
ip route-cache flow
speed auto
full-duplex
interface FastEthernet0/1
ip address 10.1.1.1 255.255.0.0
duplex auto
speed auto
ip flow-export destination 10.250.100.60 2055
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip route 10.210.0.0 255.255.0.0 10.250.1.111
ip route 10.220.2.0 255.255.255.0 10.250.1.111
ip route 10.230.0.0 255.255.0.0 10.250.1.111
ip route 10.231.0.0 255.255.0.0 10.250.1.111
ip route 10.240.0.0 255.255.0.0 10.250.1.111
ip route 10.241.0.0 255.255.0.0 10.250.1.111
ip route 10.242.0.0 255.255.0.0 10.250.1.111
ip route 172.16.0.0 255.255.0.0 10.250.1.112
ip route 172.30.1.0 255.255.255.0 10.1.1.2
ip route 192.168.3.0 255.255.255.0 10.250.1.111
ip route 192.168.4.0 255.255.255.0 10.250.1.111
ip route 192.168.100.0 255.255.255.0 10.250.1.111
ip http server
line con 0
line aux 0
line vty 0 4
password xxxxxxx
login
ntp source FastEthernet0/1
end
22 Replies 22
Paul, the ASA can only be a NTP client, not a server
Hope it Helps!
Soroush.
Everyone,
Thanks for trying to help me. I have been trying to determine:
A- Is it the ASA blocking NTP traffic?
B- Is it the NTP server itself no replying to client(2600 router)?.
I posted both configurations: Router and ASA
I set up two captures in the ASA :
     INSIDE interface
ASA(config)# access-list NTPtr permit ip any host 184.82.112.110
ASA(config)# access-list NTPtr permit ip host 184.82.112.110 any
ASA(config)# capture cap1 access-list NTPtr interface inside
ASA(config)# show capture cap1 detail
2 packets captured
   1: 10:25:15.385462 0011.9346.90c1 0024.97bb.89de 0x8100 94: 802.1Q vlan#1 P0 10.1.1.1.123 > 184.82.112.110.123:  [udp sum ok] udp 48 (ttl 255, id 0)
   2: 10:26:19.383723 0011.9346.90c1 0024.97bb.89de 0x8100 94: 802.1Q vlan#1 P0 10.1.1.1.123 > 184.82.112.110.123:  [udp sum ok] udp 48 (ttl 255, id 0)
2 packets shown
OUTSIDE interface
ASA(config)# capture cap1 access-list NTPtr interface outside
************************************************ASA <==>NTP server**********************************************
113: 11:23:57.691538 0024.97bb.89de 0011.9346.7ca1 0x8100 94: 802.1Q vlan#2 P0 X.X.X.210.65535 > 184.82.112.110.123:  [udp sum ok] udp 48 (ttl 255, id 20013)
114: 11:23:57.723488 0011.9346.7ca1 0024.97bb.89de 0x8100 94: 802.1Q vlan#2 P0 184.82.112.110.123 >
X.X.X.210.65535:  [udp sum ok] udp 48 (DF) (ttl 53, id 0)
**************************************************2600RTR<====>NTP serve*******************************************
115: 11:24:59.336972 0024.97bb.89de 0011.9346.7ca1 0x8100 94: 802.1Q vlan#2 P0 10.1.1.1.123 > 184.82.112.110.123:  [udp sum ok] udp 48 (ttl 255, id 0)
116: 11:26:03.335279 0024.97bb.89de 0011.9346.7ca1 0x8100 94: 802.1Q vlan#2 P0 10.1.1.1.123 > 184.82.112.110.123:  [udp sum ok] udp 48 (ttl 255, id 0)
I have used different NTP servers and none have worked for the router.
Does anyone still think I need to explicitly  allow the NTP traffic coming back? it is going out according to the captures but no replies from NTP server
Or could it be that the IOS version is too old in that router?
Thanks again
Johnny
Hi Johnny,
if your NTP request goes out, it's not like ntp server dont reply because of router's ios version, try to find out if u receive it on ur outside interface and if yes and drops, explicitly let it in.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Johnny,
Here's what I'm wondering. The ASA doesn't have a specific nat rule for 10.1.1.0 (or at least I'm not seeing it), but it does have the rule for 10.250.x.x which is on your lan side. Can you change the sourced interface for NTP?
If the IOS supports it, it should be "ntp source fa0/0"
HTH,
John
HTH, John *** Please rate all useful posts ***
j.blakley
i changed the NAT rule to include any ip in this range 10.0.0.0 and still does not work and did away with the source.
soroushm
How would you allow the NTP traffic coming back explicitly for that host 10.1.1.1 ?. Please specify configuration if you do not mind.
Johnny
i guess you have to add this link to ur ACL (allowing NTP from 38.106.177.10 to come in to any destination):
access-list from_outside extended permit udp host 38.106.177.10 eq 123 any
HTH,
Soroush.
Hope it Helps!
Soroush.
soroushm
Thanks again. Still not working. I even added the line like this with the NTP server we are using:
access-list from_outside extended permit ip host 184.82.112.110 any
The access counter remains in "0" hits coming back
access-list from_outside line 3 extended permit ip host 184.82.112.110 any (hitcnt=0) 0x644eb7c3
The capture show this:
   1: 06:22:02.298797 802.1Q vlan#2 P0 10.1.1.1.123 > 184.82.112.110.123:  udp 48
   2: 06:23:06.297775 802.1Q vlan#2 P0 10.1.1.1.123 > 184.82.112.110.123:  udp 48
Nothing coming back
The only thing that is interesting that I noticed is that the connection from the router initiates from port 123 as well instead of a random port, but that should not matter.
Well I guess there is nothing else to do. I think the NTP servers are not responding to those packets coming from the 2600 router perhaps due to incompatibility reason.
It is not blocking, an open ACL is there and the counters shows no hits.
Any other idea?
Johnny
Everyone,
The problem is fixed. Upgraded IOS 12.4 from 12.2 and it is working now.
sh capture cap1
4 packets captured
   1: 10:05:31.855119 802.1Q vlan#1 P0 10.1.1.1.123 > 184.82.112.110.123:  udp 48
   2: 10:05:31.886947 802.1Q vlan#1 P0 184.82.112.110.123 > 10.1.1.1.123:  udp 48
   3: 10:06:35.854173 802.1Q vlan#1 P0 10.1.1.1.123 > 184.82.112.110.123:  udp 48
   4: 10:06:36.220066 802.1Q vlan#1 P0 184.82.112.110.123 > 10.1.1.1.123:  udp 48
4 packets shown
sh ntp status
Clock is synchronized, stratum 3, reference is 184.82.112.110
reference time is D39844BB.E271D517 (10:14:03.884 CDT Fri Jun 29 2012)
clock offset is -1.4301 msec, root delay is 35.37 msec
root dispersion is 7907.09 msec, peer dispersion is 7875.24 msec
NO CHANGES required in configuration. I removed the ACL that was suggested and changed NAT statement back the way it was
ASA allows NTP traffic originating behind "INSIDE" interface and does not need ACL to allow the traffic coming back from the NTP server.
Thanks to all that tried to help.
Johnny
