10-14-2024 02:36 AM
on cisco SGH500-48 if i have a preconfigured IP arp inspection list
ip arp inspection list create servers
ip k.k.k.k mac-address aa.aa.aa.aa.aa
ip l.l.l.l mac-address bb.bb.bb.bb
To add new entries to the ARP inspection list,
ip m.m.m.m mac-address cc.cc.cc.cc
will this wipe out the existing entries? or should i use the command like below:
Solved! Go to Solution.
10-14-2024 05:39 AM
After issuing the "ip arp inspection list create servers" you enter the ARP list configuration mode where you can either create (ie. add) or delete (ie. remove - if existing) the static ARP binding (using "ip mac"/"no ip mac" command). No existing binding is wiped out automatically when you enter the ARP list configuration mode (config-arp-list).
You can check the result via the "show ip arp inspection list" command.
So regarding your example the procedure would be as follows:
Best regards,
Antonin
10-14-2024 06:02 AM
Most cases it will add new entry - not it going to wipe old one.
In case you think that will wipe old one, then add old config in text file and add new to to the exiting mac table paste all of them so all will be safe.
10-14-2024 05:39 AM
Best regards,
Antonin
10-14-2024 06:02 AM
