Problem with my Catalyst 3550-48-SMI
danieltoro
The switch no work! The system led is solid green and other all is off. The port leds of 3-48 are solid green and they are not connect and 1-2 port leds are off. Anex the error file of console.
Any suggestions?
smothuku
Level 7
Level 7
Hi ,
The following is the decode of the traceback taken from error file.
0x1A7514:chunk_malloc(0x1a74a8)+0x6c
0x2C4AE0:vra_handle_alloc(0x2c4a30)+0xb0
0x2D74C4:map_mgr_init(0x2d7478)+0x4c
0x2B46AC:vegas_subsys_init(0x2b4298)+0x414
0x1C3C30:subsys_init_routine(0x1c3c08)+0x28
0x1C3CE0:subsys_init_class(0x1c3c40)+0xa0
0x1058D8:system_init(0x10564c)+0x28c
0x105ADC:init_process(0x105a8c)+0x50
0x1CCCD8:process_execute(0x1ccb7c)+0x15c
and
Enter hex value: 0x002B6B78
0x002B6B78:SCMoleculeSend(0x2b6b04)+0x74
Enter hex value: 0x002CB454
0x002CB454:jelk_get_link_status(0x2cb3dc)+0x78
Enter hex value: 0x0035A5E8
0x0035A5E8:vpd_poll_status(0x35a554)+0x94
Enter hex value: 0x002F12A0
0x002F12A0:vled_process(0x2f1240)+0x60
Enter hex value: 0x001CCCD8
0x001CCCD8:process_execute(0x1ccb7c)+0x15c
Enter hex value: 0x00B59768
0x00B59768:etext(0x6760f4)+0x4e3674
Enter hex value: 0x00B597B0
0x00B597B0:etext(0x6760f4)+0x4e36bc
*** Best thing is to go for RMA.
satish
glen.grant
RMA the switch . If you don't have a contract then it is time to buy a new switch . That appears to be a hardware failure .
use these commands
sh post
sh tech-support
and send the result to TAC
looks like the switch is faulty
