PVIDs vs vlans...
jimmysands73_2
Level 5
Level 5
What is a PVID used for?
It seems to me this setting is the same as making a port an access port.
ty
3 Accepted Solutions
Configuration wise .. None !!
john kennedy
Keep in mind that a given port can be a member of mulitple vlans. If you get into private Vlans, an isolated or community port is part of a "sub-vlan" if you will. Also, with VOIP, a switchport negotiates a special type of trunk port with the IP phone for the access and VOIP traffic to be separated.
As far as I know concerning PVID since I was working with Nortel stuff, when a switch receives untagged frames, it puts them on the PVID of the receiving port. So we talk about port's PVID.
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
7 Replies 7
"A Port VLAN ID (pvid) is a default VLAN ID that is assigned to an access port to designate the virtual LAN segment to which this port is connected. The pvid places the port into the set of ports that are connected under the designated VLAN ID. Also, if a trunk port has not been configured with any VLAN memberships, the virtual switch's Port VLAN ID (pvid) becomes the default VLAN ID for the ports connection."
This is one of the definition you can find around.
Hope this helps
Alessio
TY....another vendor has PVID settings, which I have not seen before as I work nornally with Cisco and Extreme.  So what is the difference between a PVID say of 10 and sw ac vla 10?
mhnedirli
Some vendors also using pvid as private vlan id.such as allied telesys
Sent from Cisco Technical Support Android App
john kennedy
Thanks all, makes sense.
