Rate Limiting port on Catalyst 3550
gregwoodson
I am having the same issue as listed in the following case:
https://supportforums.cisco.com/thread/161768
However- even when this is set as an access port- it is not doing rate limiting- should be rate limited to 2Mb (one port traffic goes in- one port traffic goes out- only 2 nodes on the switch).  The relevant config is listed below:
class-map match-all HOC-CAM
match access-group 100
policy-map CAM-LIMIT
class HOC-CAM
    police 2000000 32000 exceed-action drop
interface FastEthernet0/1
description Connection to HOC Camera
switchport mode access
load-interval 30
service-policy input CAM-LIMIT
interface FastEthernet0/24
description Uplink to HOC-1611Main-Catalyst
switchport mode dynamic desirable
access-list 100 permit ip any any
Any suggestions?
acampbell
Your config looks OK to me but have you enable qos
mls qos
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
mls qos
Alex.
