Remotely changing a port from access to trunk
RonaldNutter
I have a switch in a building across the street that we are going change a port from access to trunk so that we can accomodate multiple vlan's in that building.
The port config is as follows -
switchport access vlan XX
switchport mode access
speed 100
duplex full
spanning-tree portfast
Would the following let me change it to trunk remotely ?
no spanning-tree portfast
switchport trunk native vlan xx
switchport mode trunk
After the last command, I am sure that I would loose the connection once I issue the switchport mode trunk command but would think I would get it back in a minute or so.
Would appreciate any suggestions.
Ron
2 Accepted Solutions
glen.grant
  Yes that should work , just make sure "switchport mode trunk " is the last command. You will lose it at this point until you configure ther other side.  You could also make the last command switchport mode dynamic desirable"  which will negotiate the trunk .
jimmysands73_2
Level 5
Level 5
And of course if you are hesitant, use the reload in X command.
glen.grant
jimmysands73_2
Level 5
Level 5
Thanks for all the replies.  The reload in X command is one I always keep in my back pocket for remote situations like this.  Everything went smoothly.
Ron
Leo Laohoo
There's an easier way.
1.  Open a text file, like notepad, and enter the following:
!  Line below will clear out the config of your choice
default interface
interface
switchport encap dot
2.  Next save the config to the default folder of your TFTP server.
3.  Telnet/SSH into the switch;
4.  Go to enable mode;
5.  Command:  copy tftp:///.extension run
Done.
