Router Port-Channel to switch
David Lee
I am trying to create a Port-Channel between a Cisco 1921 router and a 2960 Switch.  Either I am missing something or I am having a temporary memory loss.  I cant seem to get a port-channel to come up between the two.  I've done it numerous times on a 3750X switch and end devices, but not with a router and a switch.  The switch gives back an error message
LACP currently not enabled on the remote port.
When I try to turn LACP on the router port, it doesnt work.  I know that I am missing something simple.
Borgenstrand
Hi David,
LACP might be supported only on etherswitch modules and not on the built-in ports.
Does it work if you do not use LACP but just enable port-channel group manually?
https://supportforums.cisco.com/discussion/11227006/lacp-isr-g2-1921-how
5 Replies 5
Borgenstrand
Hi David,
Helllo
Please post the config -but a standard routed port  etherchannel config would
Int port-channel 10
ip address X.x.x. y.y.y.y.
default interface range X/X - x
interface range X/X -x
no switchport
shut
channel-group 10 mode active
No shut
res
paul
Kind Regards
Paul
here is the show-run.  I am using a HWIC-2FE to try and make this work.
C1921#sh run
Building configuration...
Current configuration : 1514 bytes
! Last configuration change at 19:23:53 UTC Sun May 15 2016
version 15.3
hostname C1921
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX
redundancy
interface Port-channel1
 ip address 192.168.100.252 255.255.255.0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet0/0/0
 no ip address
 duplex auto
 speed auto
 channel-group 1
interface FastEthernet0/0/1
 no ip address
 duplex auto
 speed auto
 channel-group 1
interface FastEthernet0/1/0
 no ip address
interface FastEthernet0/1/1
 no ip address
interface FastEthernet0/1/2
 no ip address
interface FastEthernet0/1/3
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
C1921#
David Lee
That was it. I turned LACP off on the switch and the Ether-channel came up.
C1921#sh int port-channel 1
Port-channel1 is up, line protocol is up
  Hardware is FEChannel, address is 5087.89c0.c49e (bia 0000.0000.0000)
  Internet address is 192.168.100.252/24
  MTU 1500 bytes, BW 200000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Unknown duplex, Unknown Speed
    No. of active members in this channel: 2
        Member 0 : FastEthernet0/0/0 , Full-duplex, 100Mb/s
        Member 1 : FastEthernet0/0/1 , Full-duplex, 100Mb/s
    No. of Non-active members in this channel: 0
    No. of PF_JUMBO supported members in this channel : 0
  Last input 00:00:14, output never, output hang never
how do you turn off lacp?
