show interface output format
tedauction
Level 5
Level 5
Hello, I was wondering why the output from the 'sh inteface' command, underneath '5 minute output rate' is indented ?
Is there any specific reason for this ?
Yashas Bhadoria
the level of traffic going through the router is just too low, resulting in this statistical analysis.
You could try and change the value of the interface load-interval down to 30 seconds:
conf t
interface f0/0
load-interval 30
I would suggest setting the load-interval to 30 seconds, this will give you a better representation of the bandwidth at the times you are issuing the command.  Can you set the load interval by issuing the "load-internal 30" interface command.
Also please refer to the following links:
https://supportforums.cisco.com/discussion/11050996/why-5-minute-input-output-rate-are-0-bits
https://learningnetwork.cisco.com/thread/38916
tedauction
Level 5
Level 5
Hello, thanks for your reply, however I am simply referring to why the information underneath the '5 minute output rate' line is indented i.e. tabbed in from the left hand edge.
Thanks for any info.
