Static ip address
zamoha0094
Visitor
I have cisco core 4500 configured on it DHCP, The DHCP POOL configured and IP excluded range was configured too.
The PC's and Printer taking automatically the IP's, but when I setup static IP on PC & printer I can't ping the default gateway and PC can't access to the internet?
8 Replies 8
Mark Elsen
 - I can't see the purpose of this 'static exercise' which is indeed prone to errors. if certain parameters are not entered correctly; keep using DHCP as much as possible.
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
luis_cordova
Hi @zamoha009,
Could you show us the DHCP pool configured for those devices and the ip parameters that you are configuring?
It would be useful if you also show us the configuration of the interface where the gateway of that network is hosted.
find the output configuration for DHCP
ip domain-name moh.gov.sa
ip dhcp excluded-address 10.135.49.129 10.135.49.133
ip dhcp excluded-address 10.135.50.1 10.135.50.5
ip dhcp excluded-address 10.135.50.129 10.135.50.133
ip dhcp excluded-address 10.135.52.1 10.135.52.5
ip dhcp excluded-address 10.135.52.129 10.135.52.133
ip dhcp excluded-address 10.135.53.1 10.135.53.5
ip dhcp excluded-address 10.135.53.129 10.135.53.133
ip dhcp excluded-address 10.135.54.1 10.135.54.5
ip dhcp excluded-address 10.135.54.129 10.135.54.133
ip dhcp excluded-address 10.135.61.1 10.135.61.20
ip dhcp excluded-address 10.135.51.1 10.135.51.5
ip dhcp excluded-address 10.135.48.1 10.135.48.5
ip dhcp excluded-address 10.135.49.1 10.135.49.5
ip dhcp excluded-address 10.135.48.129 10.135.48.133
ip dhcp pool Wireless_Medical-Devices
network 10.135.57.0 255.255.255.128
default-router 10.135.57.1
dns-server 84.235.6.55 84.235.57.230 10.0.64.100 10.0.64.101 8.8.8.8
ip dhcp pool Wireless_MOH-Guest
network 10.135.57.128 255.255.255.128
default-router 10.135.57.129
ip dhcp pool MGMT
network 10.135.61.0 255.255.255.128
default-router 10.135.61.1
ip dhcp pool DATA_CENTER-GF-AS01
network 10.135.48.0 255.255.255.128
default-router 10.135.48.1
ip dhcp pool DATA_CENTER-GF-AS02
network 10.135.48.128 255.255.255.128
default-router 10.135.48.129
ip dhcp pool DATA_Main-hospital-GF-AS01
network 10.135.49.0 255.255.255.128
default-router 10.135.49.1
ip dhcp pool DATA_Main-HR-F1-AS01
network 10.135.49.128 255.255.255.128
default-router 10.135.49.129
ip dhcp pool VOICE_CENTER-GF-AS01
network 10.135.52.0 255.255.255.128
default-router 10.135.52.1
ip dhcp pool VOICE_CENTER-GF-AS02
network 10.135.52.128 255.255.255.128
default-router 10.135.52.129
ip dhcp pool VOICE_Main-hospital-GF-AS01
network 10.135.53.0 255.255.255.128
default-router 10.135.53.1
ip dhcp pool VOICE_Main-HR-F1-AS01
network 10.135.53.128 255.255.255.128
default-router 10.135.53.129
ip dhcp pool VOICE_STORE-GF-AS01
network 10.135.54.0 255.255.255.192
default-router 10.135.54.1
ip dhcp pool Wireless_MOH-Employee
network 10.135.56.0 255.255.255.0
default-router 10.135.56.1
ip dhcp pool DATA_STORE-GF-AS01
network 10.135.50.0 255.255.255.128
default-router 10.135.50.1
ip dhcp pool DATA_AKU-GF-AS01
network 10.135.50.128 255.255.255.192
default-router 10.135.50.129
ip dhcp pool DATA_OLD-NETWORK
network 10.135.51.0 255.255.255.0
default-router 10.135.51.1
dns-server 212.93.192.4 212.93.192.5 10.0.64.100 10.0.64.101
ip dhcp pool VOICE_AKU-GF-AS01
network 10.135.54.128 255.255.255.192
default-router 10.135.54.129
Georg Pauwen
post the config of your 4500. In addition to the other post, you can also create a static DHCP mapping for your printers and PCs.
balaji.bandi
Why not reserve the IP address for the MAC Address, and set the Device to use DHCP, so Device get right IP address what you looking to achieve, can you post the screen of the IP address information from your PC ?
BB
Hello
The best solution would be to use dhcp and reserve the ip addressing against each static host or printer, meaning these hosts will be configured to use dhcp and their allocated ip addresses will always be assigned to them so from the hosts perspective they are just using dhcp like any other host.
To accomplish this you need to reserve each individual ip addresses in the dhcp scope against each host mac- address, This way you wont have to configure any host manually and also you are least prone to any ip address conflicts or mis-configuration.
What type dhcp server are you using?
Kind Regards
Paul
Hello Paul,
I'm using Cisco core 4500-x, I know this solution to resolve the IP and mac for the specific machine.
my concern as I remember when you put static on pc or printer from excluded it will reachable toward the core, but on this core 4500-x  it doesn't work.
Hi Zamoha,
It should be straight forward would you please share the running configuration and connectivity flow in order to provide you with the solution.
BR
Tayyab - www.tayyabmunir.com
***Please rate ***
*** Please rate all helpful responses and mark solutions***
