Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
Hi everyone,  I’m experiencing a strange issue on one of our Cisco switches: several interfaces (e.g., `GigabitEthernet2/0/5`, `2/0/9`, `2/0/11`, `2/0/13`, `2/0/14`, etc.) are continuously going **up and down every few seconds**.  I dont have any hub...
chpmotry by Level 1
  • 1 Views
  • 1 replies
IOS-XE Update Failure (Catalyst Center)We are trying to update the equipment, running in install mode, and it fails deployment due to lack of space. The command: [ install remove inactive ] does not correct the problem. Is there a document that lists...
Hi, I got a Catalyst 1000 switch (C1000-8FP-E-2G-L)When i try to open the GUI i get this: When i click on "Web Console - Manage the Switch through the web interface." i get 404 Not Found Any ideas?!
Moudar by VIP Alumni
  • 11920 Views
  • 16 replies
Hi TeamMy cisco switch 3850 stop working and show all start up lights, the Stat, duplex, speed, stack, PoE and syst shows green.The ACTV, XPS,S-PWR show yellow light.The switch was working few minutes ago.Please help with solution as this is my main ...
we have a 9407 and several small business edge switches, we recently had an issue where we lost internet connection in the whole facility, we started troubleshooting using elimination; we were able to identify the switches that created the issue. How...
Hi,we do have migrated our Cisco 6807 to cisco C9606R.we are in version 17.12.5.Since we have migrated we have a problem with Hitachi server Hearbeat connected on C9600-LC-48YL line card.we have the following configuration :NAME: "FiftyGigE1/1/0/20",...
jerome-mi by Community Member
  • 150 Views
  • 8 replies
I am trying to setup an IP HELPER-ADDRESS per SVI but clients are not getting IP address from the assigned DHCP Server in the IP HELPER Address.  C1300-24XT has also different syntax or argument in declaring IP HELPER-ADDRESS.Catalyst 1300 Series Man...
iamroy by Level 1
  • 716 Views
  • 18 replies
I have a customer who is struggling with the Thumbscrews that are used to secure these cables to the routers.   I am trying to find out if there is a part number associated with them and if it is possible to purchase replacement screws.     Or if the...
sfein by Level 1
  • 261 Views
  • 2 replies
