unable to enable routing in 3750x switch
EZRA SHYAM
im unable to enable ip routing in the WS-C3750X-24T-L switch. Tried with SDM prefer routing option but still same issue.
Can some suggest on this?
MOdel: WS-C3750X-24T-L
IOS :flash:c3750e-ipbasek9-mz.122-55.SE5.bin
sh license
Index 1 Feature: ipservices
        Period left: 0  minute  0  second
Index 2 Feature: ipbase
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        License Count: Non-Counted
regards,
Ezra.
13 Replies 13
Sandeep Choudhary
Did u tried:
Switch(config )# ip routing
hi sandeep,
there is no option to enable ip routing in the switch.
(config)#ip routing
% Invalid input detected at '^' marker.
Pls enable this command
sdm prefer lanbase-routing
reload the switch & then try
Pls rate if helpful
Br/Suibhojit
HI Ezra,
Please update your licence.
Contact your cisco supplier, and buy the upgraded license.
Dontforget to rate helpful posts.
You don't have the license to run routing.
So the only option is to enable licence?
You can't enable the IP Services DEMO license because you've used it all up.
Your only option is to purchase the IP Service license from your authorized Cisco reseller.
HI,
Hope you have tried this option
sdm prefer lanbase-routing  ---> this is to help us to enable 'ip routing' with non routing supported image
Reload the switch & then try to enable 'ip routing'
Br/Subhojit
Update the new image which supports ip routing .
Hi suibhojit,
i dont have option to enable the option sdm prefer lanbase-routing.
config)#sdm prefer ?
  access              Access bias
  default             Default bias
  dual-ipv4-and-ipv6  Support both IPv4 and IPv6
  routing             Unicast bias
  vlan                VLAN bias
HI,
Just check with routing once,
then reload & try to give 'ip routing'
Br/Subhojit
tried with that... but no luck.
HI,
Pls share this command output & also ISP version
sh sdm prefer routing
