verification of the layer 2 connection
axfalk
we're creating an etherchannel between the two 10GE ports on the 6509's and I was wandering if there were a conclusive way to verify that the Layer 2 was working between these switches? I was thinking of may be pulling the cable off one of the switches or something like that...
thanks..
steve.busby
Level 5
Level 5
Wouldn't a "show etherchannel" be a little less disruptive?
http://www.cisco.com/en/US/tech/tk389/tk213/tsd_technology_support_troubleshooting_technotes_list.html
Steve
bvsnarayana03
Level 5
Level 5
show etherchannel [channel-group] {port-channel | brief | detail | summary | port | load-balance | protocol}
Syntax Description
channel-group
(Optional) Number of the channel group; valid values are a maximum of 64 values from 1 to 282.
port-channel
Displays the port-channel information.
brief
Displays a summary of EtherChannel information.
detail
Displays the detailed EtherChannel information.
summary
Displays a one-line summary per channel group.
port
Displays the EtherChannel port information.
load-balance
Displays load-balance information.
protocol
Displays the enabled protocol.
dinesh_mih
HI,
you can issue show eth sum command and check that both the interfaces are being shown as UP. If they are showing up then you cna be sure that ether-channel is working fine. In order to finally chekc the things plug out one cable and see if networks keeps working fine. You can issue a ping and see while plugging the cable out that ping response is not broken. I will recommend to do this testing during off hours to avoid any issues.
Dinesh
http://Knowurtech.com
(Good technical articles. Submit your articles and get featured on our website. Send email to articles@knowurtech.com. To know the benefits http://www.knowurtech.com/be_an_expert.html)
HI,
Dinesh
