VLAN Creation Issue on cisco WS-C3548-XL
sanjeevmahadani
Hi All,
I am trying to create an anotherb Vlan 97 on cisco WS-C3548-XL but unable to made up the vlan interface .
S35_PKS_A32#sh vlan
VLAN Name                             Status    Ports
1    default                          active
5    Admin                            active
27   VLAN0027                         active
32   VLAN0032                         active    Fa0/13, Fa0/25
33   VLAN0033                         active    Fa0/8, Fa0/14, Fa0/27, Fa0/37,
                                                Fa0/38, Fa0/42
36   VLAN0036                         active
37   VLAN0037                         active    Fa0/1, Fa0/2, Fa0/3, Fa0/4,
                                                Fa0/7, Fa0/9, Fa0/10, Fa0/12,
                                                Fa0/16, Fa0/18, Fa0/19, Fa0/20,
                                                Fa0/21, Fa0/22, Fa0/26, Fa0/29,
                                                Fa0/30, Fa0/31, Fa0/33, Fa0/34,
                                                Fa0/36, Fa0/43, Fa0/44, Fa0/45,
                                                Fa0/46, Fa0/47, Fa0/48
39   VLAN0039                         active    Fa0/5, Fa0/15, Fa0/23, Fa0/24,
                                                Fa0/32, Fa0/39, Fa0/40
40   VLAN0040                         active    Fa0/11, Fa0/28
41   VLAN0041                         active
44   VLAN0044                         active
47   VLAN0047                         active
48   VLAN0048                         active
50   VLAN0050                         active
54   VLAN0054                         active    Fa0/41
57   VLAN0057                         active
60   VLAN0060                         active
65   VLAN0065                         active
66   VLAN0066                         active
96   VLAN0096                         active
97   VLAN0097                         active
104  VLAN0104                         active    Fa0/17
130  VLAN0130                         active    Fa0/6, Fa0/35
323  VLAN0323                         active
500  VLAN0500                         active
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
5    enet  100005     1500  -      -      -        -    -        0      0
27   enet  100027     1500  -      -      -        -    -        0      0
32   enet  100032     1500  -      -      -        -    -        0      0
33   enet  100033     1500  -      -      -        -    -        0      0
36   enet  100036     1500  -      -      -        -    -        0      0
37   enet  100037     1500  -      -      -        -    -        0      0
39   enet  100039     1500  -      -      -        -    -        0      0
40   enet  100040     1500  -      -      -        -    -        0      0
41   enet  100041     1500  -      -      -        -    -        0      0
44   enet  100044     1500  -      -      -        -    -        0      0
47   enet  100047     1500  -      -      -        -    -        0      0
48   enet  100048     1500  -      -      -        -    -        0      0
50   enet  100050     1500  -      -      -        -    -        0      0
54   enet  100054     1500  -      -      -        -    -        0      0
57   enet  100057     1500  -      -      -        -    -        0      0
60   enet  100060     1500  -      -      -        -    -        0      0
65   enet  100065     1500  -      -      -        -    -        0      0
66   enet  100066     1500  -      -      -        -    -        0      0
96   enet  100096     1500  -      -      -        -    -        0      0
97   enet  100097     1500  -      -      -        -    -        0      0
104  enet  100104     1500  -      -      -        -    -        0      0
130  enet  100130     1500  -      -      -        -    -        0      0
323  enet  100323     1500  -      -      -        -    -        0      0
500  enet  100500     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
S35_PKS_A32#
S35_PKS_A32#sh run int vlaN 97
Building configuration...
Current configuration:
interface VLAN97
ip address 172.23.21.8 255.255.255.0
no ip directed-broadcast
no ip route-cache
shutdown
end
S35_PKS_A32#sh int vlaN 97
VLAN97 is administratively down, line protocol is down
  Hardware is CPU Interface, address is 0008.a31c.f180 (bia 0008.a31c.f180)
  Internet address is 172.23.21.8/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Encapsulation ARPA
S35_PKS_A32#
Pls. help me to made it up the vlan port
Version:
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC3b, RELEASE SOFTWA
RE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 15-Feb-02 10:51 by antonino
Image text-base: 0x00003000, data-base: 0x00337600
ROM: Bootstrap program is C3500XL boot loader
S35_PKS_A32 uptime is 18 minutes
System returned to ROM by reload
System image file is "flash:c3500XL-c3h2s-mz.120-5.WC3b.bin"
cisco WS-C3548-XL (PowerPC403) processor (revision 0x01) with 16384K/1024K bytes
of memory.
Processor board ID FOC0602S04L, with hardware revision 0x00
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:08:A3:1C:F1:80
Motherboard assembly number: 73-3903-11
Power supply part number: 34-0971-02
Motherboard serial number: FOC06010056
Power supply serial number: APQ05430BJB
Model revision number: N0
Motherboard revision number: B0
Model number: WS-C3548-XL-EN
System serial number: FOC0602S04L
Configuration register is 0xF
S35_PKS_A32#
S35_PKS_A32#
Hey Leo,
Many a good tune out of an old fiddle.
Sanjeev
Here the config guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc3/swg/sc.html
These old switches are NOT routers
They only support ONE interface Vlan which is use for management, remote telnet etc.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
5 Replies 5
siddhartham
Level 4
Level 4
What error message did you get when you tried "no shut" under int vlan 97
Siddhartha
Siddhartha
Leo Laohoo
Wow.  Your switch is 10 years old and running an equally 10-year-old IOS.
Hey Leo,
Sanjeev
Alex.
glen.grant
  You are getting a layer 2 vlan and a layer 3 svi mixed up .  As previous poster  said this is a layer 2 switch only so the only reason to have an  SVI defined is to manage the switch.  I'm  assuming it already  has a l3 SVI to manage it so I would leave that alone and delete  the  layer 3 svi for vlan 97.   Seeing that there are so many vlans on the switch that means you have a trunked link somewhere to the L3 device which does the routing .  You already have a L2 vlan defined for vlan 97 as shown in the show vlan command so you  should be set to go .  If you need routing for this subnet it is done on another device that is attached via a trunk .
Thanks All for the clear Information. Need some replacement.
Reg
Sanjeev
