vPC from FEX interfaces
Tyler Woods
I am trying to create a vPC port-channel for two different FEX interfaces. We have two Nexus 5000 series switches connected via vPC and FEX 106 and 107 each with a connection to our Nexus 5000 switches (proda1 and proda2) connected via port-channel and vPC.
The following configuration is working at the moment:
interface port-channel201
  description pdxnas03
  switchport access vlan 100
interface Ethernet106/1/31
  description pdxnas03-e1a
  speed auto
  channel-group 201 mode passive
interface Ethernet107/1/31
  description pdxnas03-e2a
  speed auto
interface port-channel202
  description pdxnas04
interface Ethernet106/1/32
  description pdxnas04-e1a
  speed auto
  channel-group 202 mode passive
interface Ethernet107/1/32
  description pdxnas04-e2a
  speed auto
Per this Cisco document I had attempted to port-channel201 in vpc 201 and port-channel202 in vpc 202 yet receive this error no matter how I try it:
ERROR: Operation failed: [vPC already exists]
When attempting to look up any details for vpc 201 or 202 the system says it does not exist yet I still get the above error. When I issue the followign commands I get the results below.
Command: show interface port-channel201
Pertinent Portion: vPC Status: Up, vPC number: 262344
Command: show interface port-channel202
Pertinent Portion: vPC Status: Up, vPC number: 262345
Can anyone explain what is going on here? The document I followed is the same I have followed when configuring vPC port-channel interfaces for all my FEX units. I have tried making these vPC with and without LACP.
Any advice or knowledge on helping me understand this would be greatly appreciated.
Colby Beam
So from my understanding you have something similar to the following topology
http://www.cisco.com/en/US/i/300001-400000/330001-340000/331001-332000/331179.jpg
If so, then you do not need to VPC the port-channels off the FEX, as they are already VPC on the 5k side
For example:
Step 7
Configure a host port channel on each FEX
Example:
NX-5000-1(config)# interface eth101/1/1, eth101/1/2
NX-5000-1(config-if)# channel-group 2 mode active
NX-5000-1(config-if)# interface eth102/1/1, eth102/1/2
NX-5000-1(config-if)# int po2
NX-5000-1(config-if)# switchport access vlan 10
NX-5000-2(config)# interface eth101/1/1, eth101/1/2
NX-5000-2(config-if)# channel-group 2 mode active
NX-5000-2(config-if)# interface eth102/1/1, eth102/1/2
NX-5000-2(config-if)# int po2
NX-5000-2(config-if)# switchport access vlan 10
This can be found in the following document.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/layer2/513_n1_1/b_Cisco_n5k_layer2_config_gd_rel_513_N1_1_chapter_01010.html
5 Replies 5
Colby Beam
For example:
Step 7
Example:
Yes! Thank you Colby Beam. Was not aware I have enhanced vPC here. This makes a lot of sense now given the errors I was getting back.
Great! Could you mark this as resolved, so it helps other people in the future as well?
champion-c
Have features changed over time ?  I am getting an error
"Members in multiple FEX : Members must belong to same FEX"
