WS-X6708-10GE - Module 13 installation makes this system non-NEBS compliant
Vinnfier93
Hi all,
Just want confirmation with this, is this really hardware issue based on the log was given?
The SW cannot be detected by the chassis.
SPMY-3A-IDF1#show module
Mod Ports Card Type                              Model              Serial No.
  1   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-45AF   SAL1413DZ96
  2   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-45AF   SAL1412DB96
  3   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-45AF   SAL1413DZBN
  4   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-45AF   SAL1413DZE2
  5   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-45AF   SAL1446ZY97
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAD104305LL
 13    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1336XWZY
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  68ef.bd5f.0ca0 to 68ef.bd5f.0ccf  12.6   7.2(1)       12.2(33)SXJ1 Ok
  2  68ef.bd5f.02b0 to 68ef.bd5f.02df  12.6   7.2(1)       12.2(33)SXJ1 Ok
  3  68ef.bd5f.0fa0 to 68ef.bd5f.0fcf  12.6   7.2(1)       12.2(33)SXJ1 Ok
  4  68ef.bd5f.0eb0 to 68ef.bd5f.0edf  12.6   7.2(1)       12.2(33)SXJ1 Ok
  5  c471.fe16.32f8 to c471.fe16.3327  12.6   7.2(1)       12.2(33)SXJ1 Ok
  7  000a.b818.9fe8 to 000a.b818.9feb   5.2   8.4(2)       12.2(33)SXJ1 Ok
 13  0026.cb0c.41c8 to 0026.cb0c.41cf   2.5   Unknown      Unknown      Other
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1412DMY3  2.5    Ok
  2  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1413DV9M  2.5    Ok
  3  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1412DHNV  2.5    Ok
  4  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL1412DN01  2.5    Ok
  5  IEEE Voice Daughter Card    WS-F6K-48-AF       SAL14470FTB  2.5    Ok
  7  Policy Feature Card 3       WS-F6K-PFC3BXL     SAD104007SB  1.8    Ok
  7  MSFC3 Daughterboard         WS-SUP720          SAD104309V1  2.5    Ok
 13  Distributed Forwarding Card WS-F6700-DFC3C     SAL1336XRXL  1.6    Other
*Jan  3 04:56:09 MYT: %C6KENV-SP-6-NONNEBSCOMP: Module 13 installation makes this system non-NEBS compliant
*Jan  3 04:56:16 MYT: %C6KENV-SP-6-NONNEBSCOMP: Module 13 installation makes this system non-NEBS compliant
*Jan  3 04:56:17 MYT: %C6KENV-SP-6-NONNEBSCOMP: Module 13 installation makes this system non-NEBS compliant
11 Replies 11
marce1000
          - What is the exact model of the (parent) switch ?
 M.
Hi Marce,
Its WS-C6513-E.
depending on the exact module you have, check Table 1 in the document linked below for any compatibility issues:
Cisco Catalyst 6500 Series 10 Gigabit Ethernet Interface Modules Data Sheet
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/product_data_sheet09186a00801dce34.html
balaji.bandi
read the release notes :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/release/notes/ol_14271/hardware.html#23188
Does your system have a compliance meet - like to support the temperature and FAN modules?
BB
Hi Balaji.bandi,
I have received log files that contain command #show tech-support. unfortunately, that chassis does not support
command #show env all. it's weird when i can't find that command. most of switch i handled can use that command.
Did I answered your question btw?
I also found the information linked below (on the HP website, weird enough):
https://support.hpe.com/hpesc/public/docDisplay?docId=emr_na-c02675666
Hi Georg,
I've read link that you gave. Do you mean it related to the supervisor WS-SUP720? this switch is using that WS-SUP720 actually.
yes, in that table there is a column that lists the supervisor modules required for each card.
amikat
Level 7
Level 7
You are using different versions of the PFC3x and DFC3x boards namely PFC3BXL with SUP720 and DFC3C with WS-X6708-10GE module. While in theory this only means that the resultant mode is PFC3B, when a line card with DFC3C is inserted (OIR) into a switch with SUP720-3BXL, the line card sometimes does not power up.
I.E.: If you have inserted your WS-X6708-10GE module into a running system you would need a reboot as this module must be installed at boot up. If your module was installed at boot up please disregard this post.
Best regards,
Antonin
You mean I need to reboot after inserting the line card, right?
Hafiz
Yes provided you have OIR inserted the module when the system was already running the reboot with the the module inserted may solve the problem.
Best regards,
Antonin
